I have recently received FEFF8 and have been doing some trial
calculations and have come across a problem that has been deiscussed
previously on this list...... that of the limit in the number of
potentials that can be included in a calculation. I have tried
changing the value of the paramaters and the memory alocated to the
the charater variables as suggested but the code then fails at another
point. Even with a compiled version of the code with nphx = 9 I get
the following the error when running the simple sf6 example job:
[gj224@byrhtnoth sf6]$ ../feff82_morepot.x
Feff 8.20
Use NOHOLE to calculate without core hole.
Only ihole greater than zero are allowed.
RDINP
However if I use the standard program the job runs fine -
unfortunately the standard code is not sufficient for the systems I
wish to study........
Does anyone have a further way round this issue?
___________________________
Glenn Jones
Department of Chemistry Lensfield Road
University of Cambridge UK CB2
1EW
01223 336508 ___________________________
