[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
nphx > 7 ............
Title: nphx > 7 ............
dear Glenn:
I played with changing the number of potential some time ago, and managed to get FEFF to run to completion with 30 independent potentials. I'm afraid I can't find my notes after a move, but I think the following are the most important points.
First, the dimensions statements, change both the number of potentials and the max number of angular momentum arrays. I cannot tell you exactly how these are related (John or Alex?) but you could try the suggestion below.
        Obviously, you must change every such statement that appears in the FEFF source code.
Second, I had problems with the g77 compiler and FEFF8.2, and suggest you might try either a commercial product, such as the Lahey compiler, or the Intel compiler that I think can be obtained free for non-commercial use.
I never used this many potentials seriously, so there may be problems I am unaware of.
good luck!
ben
Change these statements:
c      max number of unique potentials (potph)
       parameter (nphx = 7)
c      max number of ang mom (arrays 1:ltot+1)
       parameter (ltot = 24)
To something like this:
       parameter (nphx = 50)
       parameter (ltot = 40)
Benjamin Gilbert
Scientist, Earth Science Division
Lawrence Berkeley National Laboratory
1 Cyclotron Road  MS 90R1116
Berkeley, CA 94720   USA
Ph: 1-510 495 2748 (office)
Ph: 1-608 358 0194 (cell)
Fax: 1-510 486 5686
new email address:
BGilbert@lbl.gov
prior active but expiring email address:
bgilbert@eps.berkeley.edu
