[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: How to determine FOLP parameters?
Dear FEFF users,
I am trying to calculate F K-edge XANES of some hydrogen containing solid
(several model compounds imitating partially fluorided hydroxyapatite) by
FEFF8.20.
Some of the calculation was done without trouble. However in a certain model (
see the attached file "feff_inp_1.txt"), the calculation stops with following
error messages:
  WARNING: fatal error in subroutine corval. Try
    to reduce ca1 in SCF card. If does not help,
  SEND bug report to AUTHORS
  CORVAL-1
(Please see also the attached file "log1_dat_1.txt".)
Following the advice in the error message, I changed ca1 in SCF card to 0.1 or
0.05, but unfortunately it did not work.
Then I changed the folp parameter in FOLP card (determining the magnitude of
overlapping the muffin-tin radii) as follows,
  FOLP  4  0.8
 and actually it did work.  (If I am correct, this option means folp for the
other potentials are all set to be 1.0. )
I don't think so : for the other atomic species it remains to the default value (1.15).
However, I doubt this results because the shape of simulated XANES for the other
model by default folp (AFOLP) is significantly different from that by modified
folp (FOLP 4 0.8).
I am wondering if there are "strategies" for determining appropriately the folp
parameters.  If there is, could someone kindly give me the advice?
No general strategie, look at the appendix of the paper of JJ Rehr and RC Albers (Reviews of Modern Physics, Vol72, n°3, July 2000, p. 621) who discussed about that. But be happy with your result: in fact Pot 4 is for H if I read your input file, and H is a small atom: so why not folp 0.8 for H? But look at the charge transfer to check is there is some sense from the physical point of view.
Best Regards,
M. Jaouen
__________________________________________
 Michel Jaouen
 Universite de Poitiers - UFR Sciences - SP2MI
 LMP UMR 6630-CNRS
 Boulevard Pierre et Marie Curie - Teleport 2
 BP 30179
 86962 Futuroscope - Chasseneuil Cedex
  France
 Tel : (33) 5 49 49 67 37
 Fax : (33) 5 49 49 66 92
 e-mail : Michel.Jaouen@univ-poitiers.fr
