[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
How to determine FOLP parameters?
Dear FEFF users,
I am trying to calculate F K-edge XANES of some hydrogen containing solid
(several model compounds imitating partially fluorided hydroxyapatite) by
FEFF8.20.
Some of the calculation was done without trouble.  However in a certain model (
see the attached file "feff_inp_1.txt"), the calculation stops with following
error messages:
  WARNING: fatal error in subroutine corval. Try
    to reduce ca1 in SCF card. If does not help,
  SEND bug report to AUTHORS
  CORVAL-1
(Please see also the attached file "log1_dat_1.txt".)
Following the advice in the error message, I changed ca1 in SCF card to 0.1 or
0.05, but unfortunately it did not work.
Then I changed the folp parameter in FOLP card (determining the magnitude of
overlapping the muffin-tin radii) as follows,
  FOLP  4  0.8
 and actually it did work.  (If I am correct, this option means folp for the
other potentials are all set to be 1.0. )
However, I doubt this results because the shape of simulated XANES for the other
model by default folp (AFOLP) is significantly different from that by modified
folp (FOLP 4 0.8).
I am wondering if there are "strategies" for determining appropriately the folp
parameters.  If there is, could someone kindly give me the advice?
Thank you very much for your help in advance.
H. Oji
  Hiroshi Oji, Dr.
  SR Center
  Ritsumeikan University
  1-1-1  Noji-higashi
  Kusatsu
  Shiga 525-8577
  JAPAN
  E-mail oji-a@st.ritsumei.ac.jp
 * This feff8 input file was generated by WebAtoms 1.7 (Atoms 3.0beta7)
 * Atoms written by and copyright (c) Bruce Ravel, 1998-2001
 TITLE name:	Fluorohydroxyapatite F=5% (lattice point data same as Hydroxyapatite except for F)
 TITLE formula:
 TITLE sites1:	Ca1-2, O1-3, F, P
 TITLE refer1:	Nature 204 (1964) 1051-1052
 TITLE schoen:	c_6h^2
 TITLE notes1:	Kay M I, Young R A, Posner A S.
 TITLE notes2:	Neutron Diffraction data
 TITLE notes3:	mineral apatite mined in a Holly Springs, Georgia, foliated talc and serpentine quarry.
 TITLE notes4: lattice constant: a=9.43317, c=6.8851
 TITLE notes5:	data input by Dr. Hiroshi Oji on Jul. 8, 2004.
 TITLE notes6:
 TITLE notes7:
 *  F K edge energy = 696.70 eV
 EDGE      K
 S02       1.0
 *         pot    xsph  fms   paths genfmt ff2chi
 CONTROL   1      1     1     1     1      1
 PRINT     1      0     0     0     0      0
                          *** ixc=0 means to use Hedin-Lundqvist
 *         ixc  [ Vr  Vi ]
 EXCHANGE  0
                          *** Radius of small cluster for
                          *** self-consistency calculation
                          *** A sphere including 2 shells is
                          *** a good choice
                          *** l_scf = 0 for a solid, 1 for a molecule
 *         r_scf  [ l_scf   n_scf   ca ]
 SCF       4.0
                          *** Upper limit of XANES calculation.
                          *** This *must* be uncommented to
                          *** make Feff calculate full multiple
                          *** scattering rather than a path expansion
 *         kmax   [ delta_k  delta_e ]
 XANES     4.0
                          *** Radius of cluster for Full Multiple
                          *** Scattering calculation
                          *** l_fms = 0 for a solid, 1 for a molecule
 *         r_fms     l_fms
 FMS        6.2  0
                          *** Energy grid over which to calculate
                          *** DOS functions
 *         emin  emax   eimag
 LDOS      -30   20     0.1
                          *** for EXAFS:  RMAX  10.0 and uncomment
                          *** the EXAFS card
 RPATH     0.1
 *EXAFS     20
 POTENTIALS
 *    ipot   Z  element            l_scmt  l_fms   stoichiometry
        0    9   F                  1       1       0.001
        1   20   Ca                 2       2       10
        2   15   P                  2       2       6
        3    8   O                  1       1       26
        4    1   H                  1       1       2
 FOLP  4  0.8
 ATOMS                          * this list contains 329 atoms
 *   x          y          z      ipot  tag           distance
    0.00000    0.00000    0.00000  0    F             0.00000     0
    0.05637    2.35876    0.00000  1    Ca2           2.35944     1
   -2.07093   -1.13057    0.00000  1    Ca2           2.35944     2
    2.01457   -1.22820    0.00000  1    Ca2           2.35944     3
    2.80454    0.81361    1.23588  3    O3            3.17093     4
   -2.10688    2.02200    1.23588  3    O3            3.17093     5
   -0.69766   -2.83561    1.23588  3    O3            3.17093     6
    2.80454    0.81361   -1.23588  3    O3            3.17093     7
   -2.10688    2.02200   -1.23588  3    O3            3.17093     8
   -0.69766   -2.83561   -1.23588  3    O3            3.17093     9
    0.00000    0.00000    3.16577  3    O             3.16577    10
    0.00000    0.00000    2.14609  4    H             2.14609    11
    0.00000    0.00000   -3.16577  3    O             3.16577    10
    0.00000    0.00000   -2.14609  4    H             2.14609    11
    3.25304    1.59515    0.00000  2    P             3.62309    12
   -3.00796    2.01964    0.00000  2    P             3.62309    13
   -0.24508   -3.61479    0.00000  2    P             3.62309    14
    0.69766    2.83561    2.20667  3    O3            3.66017    15
   -2.80454   -0.81361    2.20667  3    O3            3.66017    16
    2.10688   -2.02200    2.20667  3    O3            3.66017    17
    0.69766    2.83561   -2.20667  3    O3            3.66017    18
   -2.80454   -0.81361   -2.20667  3    O3            3.66017    19
    2.10688   -2.02200   -2.20667  3    O3            3.66017    20
   -3.95887    0.81125    0.00000  3    O1            4.04114    21
    2.68200    3.02286    0.00000  3    O1            4.04114    22
    1.27687   -3.83411    0.00000  3    O1            4.04114    23
    2.07093    1.13057    3.44255  1    Ca2           4.17350    24
   -2.01457    1.22820    3.44255  1    Ca2           4.17350    25
   -0.05637   -2.35876    3.44255  1    Ca2           4.17350    26
    2.07093    1.13057   -3.44255  1    Ca2           4.17350    27
   -2.01457    1.22820   -3.44255  1    Ca2           4.17350    28
   -0.05637   -2.35876   -3.44255  1    Ca2           4.17350    29
   -0.99993    4.46755    0.00000  3    O2            4.57808    30
    4.36898   -1.36781    0.00000  3    O2            4.57808    31
   -3.36905   -3.09974    0.00000  3    O2            4.57808    32
    0.24508    3.61479    3.44255  2    P             4.99779    33
   -3.25304   -1.59515    3.44255  2    P             4.99779    34
    3.00796   -2.01964    3.44255  2    P             4.99779    35
    0.24508    3.61479   -3.44255  2    P             4.99779    36
   -3.25304   -1.59515   -3.44255  2    P             4.99779    37
    3.00796   -2.01964   -3.44255  2    P             4.99779    38
    4.80032    1.61685    0.00000  3    O2            5.06530    39
   -3.80039    3.34878    0.00000  3    O2            5.06530    40
   -0.99993   -4.96562    0.00000  3    O2            5.06530    41
   -1.27687    3.83411    3.44255  3    O1            5.30867    42
    3.95887   -0.81125    3.44255  3    O1            5.30867    43
   -2.68200   -3.02286    3.44255  3    O1            5.30867    44
   -1.27687    3.83411   -3.44255  3    O1            5.30867    45
    3.95887   -0.81125   -3.44255  3    O1            5.30867    46
   -2.68200   -3.02286   -3.44255  3    O1            5.30867    47
    0.69766    2.83561    4.67843  3    O3            5.51499    48
   -2.80454   -0.81361    4.67843  3    O3            5.51499    49
    2.10688   -2.02200    4.67843  3    O3            5.51499    50
    0.69766    2.83561   -4.67843  3    O3            5.51499    51
   -2.80454   -0.81361   -4.67843  3    O3            5.51499    52
    2.10688   -2.02200   -4.67843  3    O3            5.51499    53
   -2.72309    4.71654    1.71164  1    Ca1           5.70882    54
   -2.72309    4.71654   -1.71164  1    Ca1           5.70882    55
    5.44627   -0.00005    1.71164  1    Ca1           5.70890    56
   -2.72309   -4.71663    1.71164  1    Ca1           5.70890    57
    5.44627   -0.00005   -1.71164  1    Ca1           5.70890    58
   -2.72309   -4.71663   -1.71164  1    Ca1           5.70890    59
    2.72309   -4.71654    1.73091  1    Ca1           5.71463    60
    2.72309   -4.71654   -1.73091  1    Ca1           5.71463    61
   -5.44627    0.00005    1.73091  1    Ca1           5.71471    62
   -5.44627    0.00005   -1.73091  1    Ca1           5.71471    63
    2.72309    4.71663    1.73091  1    Ca1           5.71471    64
    2.72309    4.71663   -1.73091  1    Ca1           5.71471    65
   -4.36898    1.36781    3.44255  3    O2            5.72800    66
    3.36905    3.09974    3.44255  3    O2            5.72800    67
    0.99993   -4.46755    3.44255  3    O2            5.72800    68
   -4.36898    1.36781   -3.44255  3    O2            5.72800    69
    3.36905    3.09974   -3.44255  3    O2            5.72800    70
    0.99993   -4.46755   -3.44255  3    O2            5.72800    71
    1.27687    5.59906    0.00000  3    O1            5.74281    72
   -5.48736   -1.69373    0.00000  3    O1            5.74281    73
    4.21049   -3.90533    0.00000  3    O1            5.74281    74
   -0.24508    5.81838    0.00000  2    P             5.82354    75
    5.16140   -2.69694    0.00000  2    P             5.82354    76
   -4.91632   -3.12144    0.00000  2    P             5.82354    77
    0.99993    4.96562    3.44255  3    O2            6.12441    78
   -4.80032   -1.61685    3.44255  3    O2            6.12441    79
    3.80039   -3.34878    3.44255  3    O2            6.12441    80
    0.99993    4.96562   -3.44255  3    O2            6.12441    81
   -4.80032   -1.61685   -3.44255  3    O2            6.12441    82
    3.80039   -3.34878   -3.44255  3    O2            6.12441    83
 END
 TITLE formula:
 TITLE notes6:	OH-F*-HO
 TITLE notes7:
 EDGE      K
 S02       1.0
 CONTROL   1      1     1     1     1      1
 PRINT     1      0     0     0     0      0
 *         ixc  [ Vr  Vi ]
 EXCHANGE  0
                          *** a good choice
 SCF       4.0
 XANES     4.0
 *         r_fms     l_fms
 FMS        6.2  0
                          *** DOS functions
 *         emin  emax   eimag
 LDOS      -30   20     0.1
                          *** the EXAFS card
 RPATH     0.1
 *EXAFS     20
 POTENTIALS
        0    9   F                  1       1       0.001
        1   20   Ca                 2       2       10
        2   15   P                  2       2       6
        3    8   O                  1       1       26
        4    1   H                  1       1       2
    0.00000    0.00000    3.71933  3    O             3.71933    10
    0.00000    0.00000    4.73901  4    H             4.73901    11
 END
 Calculating potentials ...
    free atom potential and density for atom type    0
    free atom potential and density for atom type    1
    free atom potential and density for atom type    2
    free atom potential and density for atom type    3
    free atom potential and density for atom type    4
    initial state energy
    overlapped potential and density for unique potential    0
    overlapped potential and density for unique potential    1
    overlapped potential and density for unique potential    2
    overlapped potential and density for unique potential    3
    overlapped potential and density for unique potential    4
    muffin tin radii and interstitial parameters
 iph, rnrm(iph)*bohr, rmt(iph)*bohr, folp(iph)
    0  1.06245E+00  1.01159E+00  1.13289E+00
    1  1.71417E+00  1.62769E+00  1.14150E+00
    2  1.13800E+00  8.66855E-01  1.15000E+00
    3  1.18076E+00  1.09271E+00  1.15000E+00
    4  9.12139E-01  8.02986E-01  1.15000E+00
              Core-valence separation
 mu_old=     1.743
              SCF ITERATION NUMBER  1  OUT OF 30
 Calculating energy and space dependent l-DOS.
 It takes time ...
     point #   1  energy = -41.000
        Doing FMS for a cluster of  23 atoms around iph =  0
    0   FMS matrix (LUD) at point   1, number of state kets = 122
        Doing FMS for a cluster of  25 atoms around iph =  1
    0   FMS matrix (LUD) at point   1, number of state kets = 140
        Doing FMS for a cluster of  21 atoms around iph =  2
    0   FMS matrix (LUD) at point   1, number of state kets = 129
        Doing FMS for a cluster of  21 atoms around iph =  3
        Doing FMS for a cluster of  19 atoms around iph =  4
    0   FMS matrix (LUD) at point   1, number of state kets = 121
     point #  20  energy = -29.821
     point #  40  energy = -10.584
     point #  60  energy = -10.249
     point #  80  energy =  -9.768
  Electronic configuration
   iph    il      N_el
     0     0    1.943
     0     1    5.393
     0     2    0.000
     0     3    0.000
     1     0    0.266
     1     1    6.417
     1     2    0.653
     1     3    0.000
     2     0    1.008
     2     1    1.668
     2     2    0.934
     2     3    0.000
     3     0    1.901
     3     1    4.708
     3     2    0.000
     3     3    0.000
     4     0    0.442
     4     1    0.129
     4     2    0.000
     4     3    0.000
 mu_new=    -9.549
 Charge transfer:  iph  charge(iph)
       0    0.133
       1    0.132
       2    0.278
       3   -0.122
       4    0.086
              SCF ITERATION NUMBER  2  OUT OF 30
 It takes time ...
     point #  20  energy = -29.840
     point #  40  energy =  -9.549
     point #  60  energy =  -9.508
     point #  80  energy =  -8.355
     point # 100  energy =  -8.039
   iph    il      N_el
     0     0    1.982
     0     1    5.539
     0     2    0.000
     0     3    0.000
     1     0    0.298
     1     1    6.461
     1     2    0.761
     1     3    0.000
     2     0    1.066
     2     1    1.775
     2     2    0.988
     2     3    0.000
     3     0    1.922
     3     1    4.552
     3     2    0.000
     3     3    0.000
     4     0    0.615
     4     1    0.131
     4     2    0.000
     4     3    0.000
 mu_new=    -8.004
       0    0.426
       1    0.426
       2    1.034
       3   -0.420
       4    0.227
              SCF ITERATION NUMBER  3  OUT OF 30
 It takes time ...
     point #  20  energy = -30.001
     point #  40  energy = -10.003
   iph    il      N_el
     0     0?????????
     0     1?????????
     0     2    0.000
     0     3    0.000
     1     0    0.094
     1     1   -3.190
 Found bad counts.
  Occupation number in getorb is     6.000
  Will repeat this iteration
     1     2    0.435
     1     3    0.000
     2     0    0.074
     2     1    0.293
     2     2    0.224
     2     3    0.000
     3     0*********
 Found bad counts.
  Occupation number in getorb is     2.000
     3     1*********
 Found bad counts.
  Occupation number in getorb is     4.000
     3     2    0.000
     3     3    0.000
     4     0    0.068
     4     1    0.143
     4     2    0.000
     4     3    0.000
CORVAL-1
