[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: Right stoichiometry
This message uses a character set that is not supported by the Internet
Service. To view the original message content, open the attached message.
If the text doesn't display correctly, save the attachment to disk, and then
open it using a viewer that can display the original character set.
<<message.txt>>
Received: from zeta.aps.anl.gov ([164.54.146.65]) by cars6.CARS.APS.ANL.GOV with SMTP (Microsoft Exchange Internet Mail Service Version 5.5.2653.13)
id 1ST20K8H; Fri, 14 Feb 2003 13:28:28 -0600
Received: (from uucp@localhost)
by zeta.aps.anl.gov (8.10.2+Sun/8.10.2) id h1EJSSY03674
for <newville@cars.uchicago.edu>; Fri, 14 Feb 2003 13:28:28 -0600 (CST)
Received: from list3.u.washington.edu(140.142.8.100) by zeta.aps.anl.gov via csmap (V6.0)
id srcAAABoaOjh; Fri, 14 Feb 03 13:28:25 -0600
Received: from host (lists.u.washington.edu [140.142.56.13])
by list3.u.washington.edu (8.12.1+UW01.12/8.12.1+UW02.12) with SMTP id h1EJS709031140;
Fri, 14 Feb 2003 11:28:08 -0800
Received: from mxu2.u.washington.edu (mxu2.u.washington.edu [140.142.33.7])
by lists.u.washington.edu (8.12.1+UW01.12/8.12.1+UW02.12) with ESMTP id h1EJRgh4023734
for <feffusers@reallists.u.washington.edu>; Fri, 14 Feb 2003 11:27:42 -0800
Received: from leonardo.phys.washington.edu (leonardo.phys.washington.edu [128.95.93.14])
by mxu2.u.washington.edu (8.12.1+UW01.12/8.12.1+UW02.12) with ESMTP id h1EJRfQY021163
for <feffusers@u.washington.edu>; Fri, 14 Feb 2003 11:27:41 -0800
Received: from localhost by leonardo.phys.washington.edu
(8.8.8/UW-NDC Revision: 2.33 ) id LAA313913;
Fri, 14 Feb 2003 11:27:40 -0800 (PST)
Message-Id: <Pine.SGI.4.21.0302141123160.313336-100000@leonardo.phys.washington.edu>
Date: Fri, 14 Feb 2003 11:27:40 -0800
Reply-To: feffusers@u.washington.edu
Sender: FEFFUSERS-owner@u.washington.edu
Precedence: bulk
List-Help: <http://www.washington.edu/computing/listproc/>
List-Unsubscribe: <mailto:listproc@u.washington.edu?body=unsubscribe%20feffusers>
List-Subscribe: <mailto:listproc@u.washington.edu?body=subscribe%20feffusers%20YourName>
List-Owner: <mailto:feffusers-request@u.washington.edu> (Human contact for the list)
List-Post: <mailto:feffusers@u.washington.edu>
From: Alex Ankudinov <alex@leonardo.phys.washington.edu>
To: "FEFF Users" <feffusers@u.washington.edu>
Subject: Re: Right stoichiometry
In-Reply-To: <Pine.LNX.4.44.0302131639510.29056-100000@cab.cnea.gov.ar>
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=X-UNKNOWN
Content-Transfer-Encoding: QUOTED-PRINTABLE
X-To: FEFF Users <feffusers@u.washington.edu>
X-Listprocessor-Version: 8.1 -- ListProcessor(tm) by CREN
Hi Sergio,
Yes, you should add calculated spectra multiplied by m's.
As in you example of SnO_2, you should add M4 and M5 edges
of Sn and K-edge of O multiplied by 2. Of course the addition
should be done after transforming to Angstrom**2 or Mbarns,
as specified in FEFF8 document.
Best wishes
Alexei Ankudinov
On Thu, 13 Feb 2003, Sergio Moreno wrote:
> Dear users,
>=20
> I am starting to use feff8.20 for calculations of ELNES. My spectrum has=
=20
> 3 edges overlapped.=20
> I would like to ask you some advice about how to add properly the=20
> calculated ELNES. I am actually adding the absolute cross-sections as=20
> indicated in page 42 in the manual. Because we are dealing with a=20
> compound of the type AmXn my question is how to consider the=20
> right stoichiometry.
> I think that the stoichiometry is implicit in the list of atoms generated=
=20
> with the crystal structure data but I am not completely sure about this=
=20
> point.=20
> Is it OK or should we multiply each calculated curve by m or n?.
>=20
> Thank you in advance for your help.
>=20
> Sergio.
>=20
>=20
> --=20
> M. Sergio Moreno
> Centro At=F3mico Bariloche
> 8400 - San Carlos de Bariloche
> Argentina
>=20
