[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: charge transfer
Le lundi, 20 jan 2003, à 16:02 Europe/Paris, Paula a écrit :
Hello,
I need to find out about bonding between atoms. When l run Ldos card, the output files show the charge transfer value changes significantly in value as well as from positive to negative when l alter the number of atoms in the calculation, is this expected or does this indicate an error in my input file?
I guess there should be only one correct charge transfer value which should be the one with a large cluster.
However,
1) you should use the stoechiometry option in the potential cards (also it is not clear if you vary the number of atoms for the scf-potentials or for the FMS for ldos ? If it's for the first case you can get wrong answer if too little number of atoms) 2) I use also the NOHOLE card for that purpose (and just run modules 1 & 2).
Am l correct in thinking that this should indicate the ionicity/covalency of the bonding, e.g. zero charge transfer indicates ionic bonding?
Isn't it that zero charge transfer indicates covalent bonding ?
Best,
Gilles
