[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: "Scandinavian FEFF question"
I am forwarding this question, which was sent to me, but which is
appropriate for this mailing list.
B
To: ravel@phys.washington.edu
Subject: "Scandinavian FEFF question"
Date: Thu, 01 Aug 2002 00:36:54 +0200
Dear Bruce,
My name is Patric and I come from from Sweden.
I hope you don't mind that I send you this mail concerning a ?FEFF? problem.
I recently started to use feff8 to calculate XANES of simple molecular
clusters (such as hydrated metal ions), and I experienced that using the
FMS card would reproduce structure above the edge quite well, when
comparing to the experimental data (e.g. Eu L3 for Eu3+ aq). To improve the
intensity of the white line as well as the Fermi energy, I included the SCF
card. This card worked well a few times but most of the times the
calculations did not at all converge, and I receive messages like:
WARNING:interstitial level found above Fermi level
   Results may be unreliable. See manual for details
The input file I used here was:
   TITLE   aqua Eu3+ ion, as EuO8 (square antiprimatic geometry)
   EDGE L3   1.0
   CONTROL  1     1     1     1     1     1
  *PRINT    0     0     0     0     0     0
   SCF 3.1  1  30  0.2
   FMS 4.0
  *LDOS  -20  40  0.05
   EXCHANGE 0 3. 0.1
   POTENTIALS
   XANES 6.0
   *   ipot   z   label  lmax1  lmax2
        0     63    Eu    -1       3
        1      8    O     -1     3
   ATOMS
     0.0000000     0.0000000    0.0000000     0   Eu     0.000
     1.3943009     1.3943009   -1.3943009     1   O      2.415
    -1.3943009     1.3943009   -1.3943009     1   O      2.415
    -1.3943009    -1.3943009   -1.3943009     1   O      2.415
     1.9718392     0.0000000    1.3943009     1   O      2.415
     0.0000000     1.9718392    1.3943009     1   O      2.415
    -1.9718392     0.0000000    1.3943009     1   O      2.415
     0.0000000    -1.9718392    1.3943009     1   O      2.415
   END
I also got a message at the end of the log file saying:
WARNING: fatal error in subroutine corval. Try
   to reduce ca1 in SCF card. If does not help,
SEND bug report to AUTHORS
(? but reducing the value of ca1 did not help)
Could it be that the cluster EuO8 is too small or incomplete? In fact it is
incomplete, as I excluded the H-atoms on the water molecules. But should
that matter?
On the other hand, the calculation I did yesterday for a much larger
cluster including several coordination shells and hydrogen atoms, using
atomic coordinates from the crystal structure of ScCl3*6H2O, did converge!
The lengthy input file for this structure is given below.
I hope that my questions are not too confusing or stupid (as I do have the
feff8 manual).
Best wishes from
Patric Lindqvist-Reis, plr@ine.fzk.de
Working address in Germany is: Institut für Nukleare Entsorgung,
Forschungszentrum Karlsruhe, P.O. Box 3640, 76021 Karlsruhe, Germany
Here is the lengthy input file:
  * This feff8 input file was generated by WebAtoms 1.6 (Atoms 3.0beta6)
  * Atoms written by and copyright (c) Bruce Ravel, 1998-2001
  TITLE name: ScCl3*6H2O
  *  Sc K edge energy = 4492.0 eV
  EDGE      K
  S02       1.0
  *         pot    xsph  fms   paths genfmt ff2chi
  CONTROL   1      1     1     1     1      1
  PRINT     1      0     0     0     0      0
                           *** ixc=0 means to use Hedin-Lundqvist
  *         ixc  [ Vr  Vi ]
  EXCHANGE  0
                           *** Radius of small cluster for
                           *** self-consistency calculation
                           *** A sphere including 2 shells is
                           *** a good choice
                           *** l_scf = 0 for a solid, 1 for a molecule
  *         r_scf  [ l_scf   n_scf   ca ]
  SCF       4.0
                           *** Upper limit of XANES calculation.
                           *** This *must* be uncommented to
                           *** make Feff calculate full multiple
                           *** scattering rather than a path expansion
  *         kmax   [ delta_k  delta_e ]
  XANES     4.0
                           *** Radius of cluster for Full Multiple
                           *** Scattering calculation
                           *** l_fms = 0 for a solid, 1 for a molecule
  *         r_fms     l_fms
  FMS        4.64433  0
                           *** Energy grid over which to calculate
                           *** DOS functions
  *         emin  emax   eimag
  LDOS      -30   20     0.1
                           *** for EXAFS:  RMAX   8.0 and uncomment
                           *** the EXAFS card
  RPATH     0.1
  *EXAFS     20
  POTENTIALS
  *    ipot   Z  element            l_scmt  l_fms   stoichiometry
         0   21   Sc                 2       2       0.001
         1   21   Sc                 2       2       2
         2   17   Cl                 2       2       6
         3    8   O                  1       1       12
         4    1   H                  1       1       24
  ATOMS                          * this list contains 179 atoms
  *   x          y          z      ipot  tag           distance
     0.00000    0.00000    0.00000  0    Sc            0.00000     0
    -1.32560    0.98199    1.31721  3    O3            2.11106     1
     1.32560   -0.98199   -1.31721  3    O3            2.11106     2
    -0.53043   -1.83856    0.89994  3    O2            2.11461     3
     0.53043    1.83856   -0.89994  3    O2            2.11461     4
     1.74779    0.17778    1.67712  2    Cl1           2.42881     5
    -1.74779   -0.17778   -1.67712  2    Cl1           2.42881     6
    -2.07699    1.39653    0.94031  4    H5            2.67364     7
     2.07699   -1.39653   -0.94031  4    H5            2.67364     8
    -1.29372    2.30672    0.60639  4    H2            2.71337     9
     1.29372   -2.30672   -0.60639  4    H2            2.71337    10
     0.08272   -2.36192    1.42941  4    H3            2.76202    11
    -0.08272    2.36192   -1.42941  4    H3            2.76202    12
    -1.53801    0.72534    2.19818  4    H6            2.77914    13
     1.53801   -0.72534   -2.19818  4    H6            2.77914    14
     1.32823    2.42579    2.08189  4    H1            3.46164    15
    -1.32823   -2.42579   -2.08189  4    H1            3.46164    16
    -1.38723    0.05269    3.81637  3    O1            4.06102    17
     1.38723   -0.05269   -3.81637  3    O1            4.06102    18
     1.38723   -3.25301    2.18623  3    O1            4.15765    19
    -1.38723    3.25301   -2.18623  3    O1            4.15765    20
    -1.32823   -0.87991    3.92071  4    H1            4.23207    21
     1.32823    0.87991   -3.92071  4    H1            4.23207    22
     1.38723    3.35839    2.18623  3    O1            4.24062    23
    -1.38723   -3.35839   -2.18623  3    O1            4.24062    24
     2.24937   -3.18114    1.78791  4    H4            4.28671    25
    -2.24937    3.18114   -1.78791  4    H4            4.28671    26
     2.24937    3.43026    1.78791  4    H4            4.47470    27
    -2.24937   -3.43026   -1.78791  4    H4            4.47470    28
     0.08272    4.24948    1.42941  4    H3            4.48421    29
    -0.08272   -4.24948   -1.42941  4    H3            4.48421    30
    -1.29372   -4.30468    0.60639  4    H2            4.53560    31
     1.29372    4.30468   -0.60639  4    H2            4.53560    32
    -4.35014   -1.39653    0.05214  4    H5            4.56910    33
     4.35014    1.39653   -0.05214  4    H5            4.56910    34
    -3.21356    3.30570    0.49622  2    Cl2           4.63690    35
    -3.21356   -3.30570    0.49622  2    Cl2           4.63690    36
     3.21356    3.30570   -0.49622  2    Cl2           4.63690    37
     3.21356   -3.30570   -0.49622  2    Cl2           4.63690    38
    -0.08272    0.94378    4.57319  4    H3            4.67029    39
     0.08272   -0.94378   -4.57319  4    H3            4.67029    40
    -2.24937    0.12456    4.21469  4    H4            4.77899    41
     2.24937   -0.12456   -4.21469  4    H4            4.77899    42
     1.53801   -2.58036    3.80442  4    H6            4.84741    43
    -1.53801    2.58036   -3.80442  4    H6            4.84741    44
     1.32823   -4.18561    2.08189  4    H1            4.85982    45
    -1.32823    4.18561   -2.08189  4    H1            4.85982    46
    -0.53043    4.77284    0.89994  3    O2            4.88582    47
     0.53043   -4.77284   -0.89994  3    O2            4.88582    48
     4.88912    0.72534    1.20574  4    H6            5.08757    49
    -4.88912   -0.72534   -1.20574  4    H6            5.08757    50
     5.10153    0.98199    0.32477  3    O3            5.20533    51
    -5.10153   -0.98199   -0.32477  3    O3            5.20533    52
     4.17776    0.12456    3.22225  4    H4            5.27751    53
    -4.17776   -0.12456   -3.22225  4    H4            5.27751    54
     0.53043    1.46714    5.10266  3    O2            5.33582    55
    -0.53043   -1.46714   -5.10266  3    O2            5.33582    56
    -4.67933    0.17778    2.66956  2    Cl1           5.39021    57
     4.67933   -0.17778   -2.66956  2    Cl1           5.39021    58
     1.32560   -2.32371    4.68539  3    O3            5.39534    59
    -1.32560    2.32371   -4.68539  3    O3            5.39534    60
    -1.74779   -3.12792    4.32548  2    Cl1           5.61680    61
     1.74779    3.12792   -4.32548  2    Cl1           5.61680    62
     1.29372   -0.99898    5.39621  4    H2            5.63833    63
    -1.29372    0.99898   -5.39621  4    H2            5.63833    64
    -5.13341   -2.30672    0.38606  4    H2            5.64109    65
     5.13341    2.30672   -0.38606  4    H2            5.64109    66
    -2.07699   -5.21487    0.94031  4    H5            5.69148    67
     2.07699    5.21487   -0.94031  4    H5            5.69148    68
     1.53801    4.03104    3.80442  4    H6            5.75225    69
    -1.53801   -4.03104   -3.80442  4    H6            5.75225    70
     5.03990    0.05269    2.82392  3    O1            5.77736    71
    -5.03990   -0.05269   -2.82392  3    O1            5.77736    72
     2.07699   -1.90917    5.06229  4    H5            5.79531    73
    -2.07699    1.90917   -5.06229  4    H5            5.79531    74
    -1.74779    3.48348    4.32548  2    Cl1           5.82230    75
     1.74779   -3.48348   -4.32548  2    Cl1           5.82230    76
    -1.32560   -5.62941    1.31721  3    O3            5.93148    77
     1.32560    5.62941   -1.31721  3    O3            5.93148    78
    -4.17776   -3.18114    2.78035  4    H4            5.94169    79
     4.17776    3.18114   -2.78035  4    H4            5.94169    80
     5.09890   -0.87991    2.92826  4    H1            5.94539    81
    -5.09890    0.87991   -2.92826  4    H1            5.94539    82
    -4.17776    3.43026    2.78035  4    H4            6.07871    83
     4.17776   -3.43026   -2.78035  4    H4            6.07871    84
    -5.89670    1.83856    0.09250  3    O2            6.17737    85
     5.89670   -1.83856   -0.09250  3    O2            6.17737    86
     3.21356    0.00000    5.50638  2    Cl2           6.37551    87
    -3.21356    0.00000   -5.50638  2    Cl2           6.37551    88
    -5.09890    2.42579    3.07434  4    H1            6.42921    89
     5.09890   -2.42579   -3.07434  4    H1            6.42921    90
    -1.53801   -5.88606    2.19818  4    H6            6.46863    91
     1.53801    5.88606   -2.19818  4    H6            6.46863    92
     1.32560    4.28769    4.68539  3    O3            6.48802    93
    -1.32560   -4.28769   -4.68539  3    O3            6.48802    94
    -6.42713    0.00000    0.99245  1    Sc            6.50330    95
     6.42713    0.00000   -0.99245  1    Sc            6.50330    96
     4.67933   -3.12792    3.33304  2    Cl1           6.54134    97
    -4.67933    3.12792   -3.33304  2    Cl1           6.54134    98
     0.00000    6.61140    0.00000  1    Sc            6.61140    99
     0.00000   -6.61140    0.00000  1    Sc            6.61140   100
    -5.13341    4.30468    0.38606  4    H2            6.71053   101
     5.13341   -4.30468   -0.38606  4    H2            6.71053   102
     4.67933    3.48348    3.33304  2    Cl1           6.71863   103
    -4.67933   -3.48348   -3.33304  2    Cl1           6.71863   104
    -5.03990   -3.25301    3.17868  3    O1            6.78871   105
     5.03990    3.25301   -3.17868  3    O1            6.78871   106
    -4.35014    5.21487    0.05214  4    H5            6.79127   107
     4.35014   -5.21487   -0.05214  4    H5            6.79127   108
    -1.29372    0.99898    6.60899  4    H2            6.80811   109
     1.29372   -0.99898   -6.60899  4    H2            6.80811   110
    -5.03990    3.35839    3.17868  3    O1            6.83983   111
     5.03990   -3.35839   -3.17868  3    O1            6.83983   112
     0.00000    3.30570    6.00260  1    Sc            6.85265   113
     0.00000   -3.30570    6.00260  1    Sc            6.85265   114
     0.00000    3.30570   -6.00260  1    Sc            6.85265   115
     0.00000   -3.30570   -6.00260  1    Sc            6.85265   116
     1.74779   -6.43362    1.67712  2    Cl1           6.87452   117
    -1.74779    6.43362   -1.67712  2    Cl1           6.87452   118
     6.50984   -2.36192    0.43697  4    H3            6.93885   119
    -6.50984    2.36192   -0.43697  4    H3            6.93885   120
    -1.32823    5.73149    3.92071  4    H1            7.07009   121
     1.32823   -5.73149   -3.92071  4    H1            7.07009   122
    -0.53043   -1.46714    6.90254  3    O2            7.07665   123
     0.53043    1.46714   -6.90254  3    O2            7.07665   124
    -6.34441   -2.36192    2.42186  4    H3            7.18997   125
     6.34441    2.36192   -2.42186  4    H3            7.18997   126
     1.74779    6.78918    1.67712  2    Cl1           7.20836   127
    -1.74779   -6.78918   -1.67712  2    Cl1           7.20836   128
     2.07699    4.70223    5.06229  4    H5            7.21468   129
    -2.07699   -4.70223   -5.06229  4    H5            7.21468   130
    -3.21356    0.00000    6.49882  2    Cl2           7.24994   131
     3.21356    0.00000   -6.49882  2    Cl2           7.24994   132
     0.53043   -5.14426    5.10266  3    O2            7.26512   133
    -0.53043    5.14426   -5.10266  3    O2            7.26512   134
    -5.09890   -4.18561    3.07434  4    H1            7.27802   135
     5.09890    4.18561   -3.07434  4    H1            7.27802   136
    -0.08272   -5.66762    4.57319  4    H3            7.28305   137
     0.08272    5.66762   -4.57319  4    H3            7.28305   138
    -4.88912   -2.58036    4.79686  4    H6            7.31926   139
     4.88912    2.58036   -4.79686  4    H6            7.31926   140
     6.34441    0.94378    3.58074  4    H3            7.34602   141
    -6.34441   -0.94378   -3.58074  4    H3            7.34602   142
    -6.95756   -1.83856    1.89239  3    O2            7.44104   143
     6.95756    1.83856   -1.89239  3    O2            7.44104   144
     0.08272   -0.94378    7.43201  4    H3            7.49215   145
    -0.08272    0.94378   -7.43201  4    H3            7.49215   146
    -2.07699    1.90917    6.94291  4    H5            7.49418   147
     2.07699   -1.90917   -6.94291  4    H5            7.49418   148
    -5.89670   -4.77284    0.09250  3    O2            7.58680   149
     5.89670    4.77284   -0.09250  3    O2            7.58680   150
     5.10153   -5.62941    0.32477  3    O3            7.60404   151
    -5.10153    5.62941   -0.32477  3    O3            7.60404   152
     4.35014    1.90917    5.95046  4    H5            7.61424   153
    -4.35014   -1.90917   -5.95046  4    H5            7.61424   154
     5.13341    0.99898    5.61654  4    H2            7.67433   155
    -5.13341   -0.99898   -5.61654  4    H2            7.67433   156
    -4.35014   -1.90917    6.05474  4    H5            7.69600   157
     4.35014    1.90917   -6.05474  4    H5            7.69600   158
    -1.38723   -6.55871    3.81637  3    O1            7.71400   159
     1.38723    6.55871   -3.81637  3    O1            7.71400   160
     4.88912   -5.88606    1.20574  4    H6            7.74616   161
    -4.88912    5.88606   -1.20574  4    H6            7.74616   162
     6.50984    4.24948    0.43697  4    H3            7.78634   163
    -6.50984   -4.24948   -0.43697  4    H3            7.78634   164
    -1.32560    2.32371    7.31981  3    O3            7.79336   165
     1.32560   -2.32371   -7.31981  3    O3            7.79336   166
    -1.38723    6.66409    3.81637  3    O1            7.80380   167
     1.38723   -6.66409   -3.81637  3    O1            7.80380   168
    -1.53801    7.33674    2.19818  4    H6            7.81186   169
     1.53801   -7.33674   -2.19818  4    H6            7.81186   170
    -1.32560    7.59339    1.31721  3    O3            7.81996   171
     1.32560   -7.59339   -1.31721  3    O3            7.81996   172
     1.29372    5.61242    5.39621  4    H2            7.89253   173
    -1.29372   -5.61242   -5.39621  4    H2            7.89253   174
    -4.88912    4.03104    4.79686  4    H6            7.94749   175
     4.88912   -4.03104   -4.79686  4    H6            7.94749   176
    -5.10153   -2.32371    5.67783  3    O3            7.97891   177
     5.10153    2.32371   -5.67783  3    O3            7.97891   178
  END
 Bruce Ravel  ----------------------------------- ravel@phys.washington..edu
 Code 6134, Building 3, Room 222
 Naval Research Laboratory                          phone: (1) 202 767 5947
 Washington DC 20375, USA                             fax: (1) 202 767 1697
 NRL Synchrotron Radiation Consortium (NRL-SRC)
 Beamlines X11a, X11b, X23b, X24c, U4b
 National Synchrotron Light Source
 Brookhaven National Laboratory, Upton, NY 11973
 My homepage:    http://feff.phys.washington.edu/~ravel
 EXAFS software: http://feff.phys.washington.edu/~ravel/software/exafs/
