[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
emesh problems...
Howdy folks,
A friend of mine sent me this rather long question regarding feff8.  I
am posting it to feffusers as he sent it to me.
  Subject: emesh problems...
  To: feffdevel@u.washington.edu
  Hi there!
  i am using feff8.28, compiled with g77 -02 -ffast-math -m686 - Wall-g
  -fno-silent feff_tot.f -o feff, on a linux system, mandrake 8.2
  distribution, where g77 is
  g77 version 2.96 20000731 (Mandrake Linux 8.2 2.96-0.76mdk) (from
  FSF-g77 version 0.5.26 20000731 (Mandrake Linux 8.2 2.96-0.76mdk))
  i want to make calculation of danes and xanes spectra. To gain time, i
  want feff to calculate once the potentials and the density of states,
  then using these calculations changing only polarization and xanes/danes
  cards for new calculations.
  the ldos calculation seems to be always done, whatever the cards are for
  the modules.
  so i only use the same pot.bin for every calculation.
  then i am experiencing a problem with the "emesh": i enclose a file
  "abort.txt" with the output and the content of the file log6.dat.
  as i understand, if i do a calculation with XANES or DANES card, then
  use the file "pot.bin" for another calculation (changing polarization
  card only), setting 0 for the POT module card: with the XANES card set..
  no problem. but for a new DANES calculation the program aborts.
  well i still can recalculate the same potentials... By the way could we
  have both f' and f'' at the same time?
  thanks a lot!
  Stephane.
  ______________________________
  Stéphane GRENIER
  Dept of Physics, 510,
  Brookhaven National Laboratory
  Upton, New York, 11973, USA.
  Tel: (1-631) 344 4963
  Fax: (1-631) 344 2739
output message:
 Emesh in feff.bin and xsect.bin different.
list in: end of file
apparent state: unit 16 named fort.16
last format: list io
lately reading sequential formatted external IO
Abort
Content of the file "log6.dat":
 Calculating chi...
    Use all paths with cw amplitude ratio   4.00%
    S02  1.000  Global sig2  0.00000
 * This feff8 input file was generated by TkAtoms 3.0beta5
 * Atoms written by and copyright (c) Bruce Ravel, 1998-2001
 TITLE Structure a 195K de Daoud
 *  Mn K edge energy = 6539.0 eV
 EDGE      K
 S02       1.0
 *         pot    xsph  fms   paths genfmt ff2chi
 CONTROL   0      1     1     1     1      1
 PRINT     1      0     0     0     0      0
                          *** ixc=0 means to use Hedin-Lundqvist
 *         ixc  [ Vr  Vi ]
 EXCHANGE  0
 POLARIZATION 1 0 0
                          *** Radius of small cluster for
                          *** self-consistency calculation
                          *** A sphere including 2 shells is
                          *** a good choice
                          *** l_scf = 0 for a solid, 1 for a molecule
 *         r_scf  [ l_scf   n_scf   ca ]
 SCF       6
                          *** Upper limit of XANES calculation.
                          *** This *must* be uncommented to
                          *** make Feff calculate full multiple
                          *** scattering rather than a path expansion
 *         kmax   [ delta_k  delta_e ]
 DANES     6.0
                          *** Radius of cluster for Full Multiple
                          *** Scattering calculation
                          *** l_fms = 0 for a solid, 1 for a molecule
 *         r_fms     l_fms
 FMS        7  0
                          *** Energy grid over which to calculate
                          *** DOS functions
 *         emin  emax   eimag
 LDOS      -30   20     0.1
                          *** for EXAFS:  RMAX   8.0 and uncomment
                          *** the EXAFS card
 RPATH     0.1
 *EXAFS     20
 POTENTIALS
 *    ipot   Z  element            l_scmt  l_fms   stoichiometry
        0   25   Mn                 2       2       0.001
        1   59   Pr                 3       3       8
        2   25   Mn                 2       2       8
        3    8   O                  1       1       24
 ATOMS                          * this list contains 178 atoms
 *   x          y          z      ipot  tag           distance
    0.00000    0.00000    0.00000  0    Mn_1          0.00000     0
   -1.06240   -1.52449    0.26730  3    O_1           1.87729     1
    0.40356    0.08391    1.90085  3    O_6           1.94503     2
   -0.35142   -0.12967   -1.91765  3    O_5           1.95389     3
    1.13518    1.56045   -0.30701  3    O_2           1.95394     4
   -1.56862    1.18123    0.26042  3    O_3           1.98083     5
    1.65335   -1.18668   -0.28410  3    O_1           2.05487     6
    0.06572   -2.51503   -1.91765  1    Pr_1          3.16339     7
   -0.11732    2.58259    1.90085  1    Pr_2          3.20886     8
   -2.65003   -0.19615    1.90085  1    Pr_1          3.26716     9
    2.70326    0.19833   -1.91765  1    Pr_3          3.32029    10
   -2.72824    0.19833   -1.91765  1    Pr_3          3.34066    11
    2.78147   -0.19615    1.90085  1    Pr_1          3.37465    12
   -0.01249   -2.90950    1.90085  1    Pr_3          3.47542    13
   -0.05160    2.90732   -1.91765  1    Pr_4          3.48318    14
    2.60440    2.72643   -0.00229  2    Mn_2          3.77046    15
    0.00000    0.00000    3.80170  2    Mn_1          3.80170    16
    0.00000    0.00000   -3.83530  2    Mn_1          3.83530    17
    2.71575   -2.71117   -0.01680  2    Mn_1          3.83745    18
   -2.71575   -2.71117   -0.01680  2    Mn_1          3.83745    19
   -2.82710    2.72643   -0.00229  2    Mn_2          3.92758    20
   -3.77815   -1.18668   -0.28410  3    O_1           3.97031    21
    2.36433   -2.58150    1.90085  3    O_5           3.98339    22
   -1.06240   -1.52449    3.53440  3    O_1           3.99309    23
    1.13518    1.56045   -3.52829  3    O_2           4.02151    24
    3.86288    1.18123    0.26042  3    O_3           4.04784    25
   -1.56862    1.18123    3.54128  3    O_3           4.04926    26
    1.14713   -3.89241   -0.27722  3    O_3           4.06738    27
    2.22909    2.83540    1.90085  3    O_8           4.07695    28
    1.65335   -1.18668   -3.55120  3    O_1           4.09302    29
   -2.31219   -2.79508   -1.91765  3    O_6           4.10318    30
   -2.41050    2.73951   -1.91765  3    O_7           4.12223    31
   -1.34973    3.88478    0.28944  3    O_4           4.12275    32
   -3.06717   -2.58150    1.90085  3    O_5           4.43677    33
   -1.06240   -1.52449   -4.10260  3    O_1           4.50378    34
    3.02100    2.73951   -1.91765  3    O_7           4.50652    35
    1.36602    4.30105   -0.30624  3    O_4           4.52314    36
    1.13518    1.56045    4.10871  3    O_2           4.53929    37
   -1.56862    1.18123   -4.09572  3    O_3           4.54212    38
   -1.58057   -4.27162    0.29021  3    O_2           4.56390    39
    1.65335   -1.18668    4.08580  3    O_1           4.56459    40
   -4.29632    1.56045   -0.30701  3    O_2           4.58122    41
    3.11931   -2.79508   -1.91765  3    O_6           4.60651    42
    4.36910   -1.52449    0.26730  3    O_1           4.63514    43
   -3.20241    2.83540    1.90085  3    O_8           4.68062    44
   -3.77815   -1.18668   -3.55120  3    O_1           5.31918    45
    2.60440    2.72643    3.80399  2    Mn_2          5.35599    46
    3.86288    1.18123    3.54128  3    O_3           5.37195    47
   -5.02794    0.08391    1.90085  3    O_6           5.37591    48
    2.60440    2.72643   -3.83301  2    Mn_2          5.37664    49
    1.14713   -3.89241   -3.55808  3    O_3           5.39691    50
   -1.34973    3.88478    3.51226  3    O_4           5.40826    51
    2.71575   -2.71117    3.81850  2    Mn_1          5.41357    52
   -2.71575   -2.71117    3.81850  2    Mn_1          5.41357    53
    2.71575   -2.71117   -3.81850  2    Mn_1          5.41357    54
   -2.71575   -2.71117   -3.81850  2    Mn_1          5.41357    55
    5.43150    0.00000    0.00000  2    Mn_1          5.43150    56
   -5.43150    0.00000    0.00000  2    Mn_1          5.43150    57
    5.08008   -0.12967   -1.91765  3    O_5           5.43152    58
   -0.11135   -5.43760   -0.01451  2    Mn_2          5.43876    59
   -0.11135    5.45940   -0.01451  2    Mn_2          5.46055    60
   -2.82710    2.72643    3.80399  2    Mn_2          5.46774    61
   -2.82710    2.72643   -3.83301  2    Mn_2          5.48797    62
    4.08177    3.88478    0.28944  3    O_4           5.64235    63
   -3.77815   -1.18668    4.08580  3    O_1           5.69002    64
   -0.48666    5.35043   -1.91765  3    O_8           5.70450    65
    1.36602    4.30105   -3.52906  3    O_4           5.72881    66
   -0.35142   -0.12967    5.71935  3    O_5           5.73160    67
    0.40356    0.08391   -5.73615  3    O_6           5.75094    68
   -1.58057   -4.27162    3.51149  3    O_2           5.75113    69
    3.86288    1.18123   -4.09572  3    O_3           5.75258    70
    1.14713   -3.89241    4.07892  3    O_3           5.75364    71
    3.85093   -4.27162    0.29021  3    O_2           5.75853    72
   -4.29632    1.56045   -3.52829  3    O_2           5.77427    73
    0.30525    5.44632    1.90085  3    O_7           5.77657    74
    0.30525   -5.45068    1.90085  3    O_7           5.78068    75
   -4.28437   -3.89241   -0.27722  3    O_3           5.79513    76
    4.36910   -1.52449    3.53440  3    O_1           5.82281    77
   -1.34973    3.88478   -4.12474  3    O_4           5.82467    78
   -0.48666   -5.54657   -1.91765  3    O_8           5.88886    79
   -4.06548    4.30105   -0.30624  3    O_4           5.92629    80
   -5.78292   -0.12967   -1.91765  3    O_5           6.09396    81
    1.36602    4.30105    4.10794  3    O_4           6.10248    82
    5.83506    0.08391    1.90085  3    O_6           6.13744    83
   -1.58057   -4.27162   -4.12551  3    O_2           6.14530    84
   -4.29632    1.56045    4.10871  3    O_2           6.14612    85
    4.36910   -1.52449   -4.10260  3    O_1           6.18420    86
    2.59843   -5.29376   -1.91765  1    Pr_2          6.20106    87
    5.31418    2.58259    1.90085  1    Pr_2          6.20673    88
    2.66415    5.27851    1.90085  1    Pr_4          6.21076    89
   -5.36578   -2.51503   -1.91765  1    Pr_1          6.22851    90
    0.06572   -2.51503    5.71935  1    Pr_1          6.24825    91
   -2.76735    5.27851    1.90085  1    Pr_4          6.25572    92
   -0.11732    2.58259   -5.73615  1    Pr_2          6.29182    93
   -2.83307   -5.29376   -1.91765  1    Pr_2          6.30298    94
   -2.65003   -0.19615   -5.73615  1    Pr_1          6.32175    95
    2.70326    0.19833    5.71935  1    Pr_3          6.32913    96
   -2.72824    0.19833    5.71935  1    Pr_3          6.33984    97
    5.49722   -2.51503   -1.91765  1    Pr_1          6.34210    98
    2.78147   -0.19615   -5.73615  1    Pr_1          6.37797    99
   -5.54882    2.58259    1.90085  1    Pr_2          6.40878   100
    5.37990    2.90732   -1.91765  1    Pr_4          6.40884   101
   -0.05160    2.90732    5.71935  1    Pr_4          6.41608   102
   -0.01249   -2.90950   -5.73615  1    Pr_3          6.43186   103
    5.41901   -2.90950    1.90085  1    Pr_3          6.43771   104
   -5.44399   -2.90950    1.90085  1    Pr_3          6.45875   105
    2.59843    5.60324   -1.91765  1    Pr_2          6.46726   106
   -5.48310    2.90732   -1.91765  1    Pr_4          6.49571   107
    2.66415   -5.61849    1.90085  1    Pr_4          6.50218   108
   -2.76735   -5.61849    1.90085  1    Pr_4          6.54514   109
   -2.83307    5.60324   -1.91765  1    Pr_2          6.56505   110
    5.43150    0.00000    3.80170  2    Mn_1          6.62979   111
   -5.43150    0.00000    3.80170  2    Mn_1          6.62979   112
    4.08177    3.88478    3.51226  3    O_4           6.63990   113
   -0.11135   -5.43760    3.81621  2    Mn_2          6.64405   114
   -0.11135   -5.43760   -3.82079  2    Mn_2          6.64668   115
    5.43150    0.00000   -3.83530  2    Mn_1          6.64911   116
   -5.43150    0.00000   -3.83530  2    Mn_1          6.64911   117
   -0.11135    5.45940    3.81621  2    Mn_2          6.66190   118
   -0.11135    5.45940   -3.82079  2    Mn_2          6.66452   119
   -6.49390   -1.52449    0.26730  3    O_1           6.67580   120
    2.36433   -2.58150   -5.73615  3    O_5           6.71994   121
    3.85093   -4.27162    3.51149  3    O_2           6.73847   122
    1.36602   -6.59595   -0.30624  3    O_4           6.74288   123
    6.56668    1.56045   -0.30701  3    O_2           6.75652   124
   -2.31219   -2.79508    5.71935  3    O_6           6.77271   125
    2.22909    2.83540   -5.73615  3    O_8           6.77582   126
   -2.41050    2.73951    5.71935  3    O_7           6.78427   127
   -4.28437   -3.89241   -3.55808  3    O_3           6.79460   128
   -1.58057    6.62538    0.29021  3    O_2           6.81748   129
   -4.06548    4.30105   -3.52906  3    O_4           6.89067   130
    4.08177    3.88478   -4.12474  3    O_4           6.98326   131
   -3.06717   -2.58150   -5.73615  3    O_5           6.99822   132
    3.02100    2.73951    5.71935  3    O_7           7.02441   133
    3.85093   -4.27162   -4.12551  3    O_2           7.07787   134
   -4.28437   -3.89241    4.07892  3    O_3           7.08126   135
    3.11931   -2.79508    5.71935  3    O_6           7.08897   136
    1.14713    7.00459   -0.27722  3    O_3           7.10331   137
   -7.00012    1.18123    0.26042  3    O_3           7.10386   138
   -1.34973   -7.01222    0.28944  3    O_4           7.14680   139
   -3.20241    2.83540   -5.73615  3    O_8           7.15530   140
    7.08485   -1.18668   -0.28410  3    O_1           7.18916   141
   -4.06548    4.30105    4.10794  3    O_4           7.20432   142
    4.94484    5.35043   -1.91765  3    O_8           7.53365   143
   -6.49390   -1.52449    3.53440  3    O_1           7.54896   144
    1.13518    1.56045    7.32999  3    O_2           7.57974   145
   -1.06240   -1.52449   -7.36970  3    O_1           7.60035   146
    1.36602   -6.59595   -3.52906  3    O_4           7.60440   147
    5.32015   -5.43760   -0.01451  2    Mn_2          7.60735   148
    6.56668    1.56045   -3.52829  3    O_2           7.61611   149
    5.32015    5.45940   -0.01451  2    Mn_2          7.62294   150
   -5.02794    0.08391   -5.73615  3    O_6           7.62828   151
    1.65335   -1.18668    7.35290  3    O_1           7.62935   152
   -1.56862    1.18123   -7.37658  3    O_3           7.63346   153
    0.00000    0.00000    7.63700  2    Mn_1          7.63700   154
    0.00000    0.00000   -7.63700  2    Mn_1          7.63700   155
    6.57863   -3.89241   -0.27722  3    O_3           7.64893   156
    5.08008   -0.12967    5.71935  3    O_5           7.65082   157
   -1.58057    6.62538    3.51149  3    O_2           7.66318   158
    3.85093    6.62538    0.29021  3    O_2           7.66874   159
    4.94484   -5.54657   -1.91765  3    O_8           7.67420   160
   -5.12625    5.44632    1.90085  3    O_7           7.71713   161
   -5.12625   -5.45068    1.90085  3    O_7           7.72021   162
   -4.06548   -6.59595   -0.30624  3    O_4           7.75426   163
   -5.54285   -5.43760   -0.01451  2    Mn_2          7.76472   164
   -5.54285    5.45940   -0.01451  2    Mn_2          7.78000   165
   -6.78123    3.88478    0.28944  3    O_4           7.82051   166
   -6.49390   -1.52449   -4.10260  3    O_1           7.83110   167
   -0.48666    5.35043    5.71935  3    O_8           7.84697   168
    1.36602   -6.59595    4.10794  3    O_4           7.88973   169
    6.56668    1.56045    4.10871  3    O_2           7.90176   170
    0.30525    5.44632   -5.73615  3    O_7           7.91574   171
    0.30525   -5.45068   -5.73615  3    O_7           7.91874   172
   -7.00012    1.18123    3.54128  3    O_3           7.93332   173
    1.14713    7.00459   -3.55808  3    O_3           7.93978   174
   -1.34973   -7.01222    3.51226  3    O_4           7.95795   175
   -1.58057    6.62538   -4.12551  3    O_2           7.96327   176
   -0.48666   -5.54657    5.71935  3    O_8           7.98200   177
 END
 Bruce Ravel  ----------------------------------- ravel@phys.washington.edu
 U.S. Naval Research Laboratory, Code 6134          phone: (1) 202 767 5947
 Washington DC 20375, USA                             fax: (1) 202 767 1697
 NRL Synchrotron Radiation Consortium (NRL-SRC)
 Beamlines X11a, X11b, X23b, X24c, U4b
 National Synchrotron Light Source
 Brookhaven National Laboratory, Upton, NY 11973
 My homepage:    http://feff.phys.washington.edu/~ravel
 EXAFS software: http://feff.phys.washington.edu/~ravel/software/exafs/
