The Kramers-Kronig method finds a pair of f'(E) and f''(E) functions
which are a self-consistent Kramers-Kronig transform pair, and which also
agree with the data. For centrosymmetric systems with crystallographic
weights,
, this method uses the intensity fitting function,
where
and
, and where the energy dependent instrument
correction function
To obtain starting values for
, b, and m, f' and
f'' are estimated using Cromer-Liberman
and
values, and
Eqn. 15 is fit to the data. Then the functions f' and f''
are obtained by using an iterative procedure: Equating the fitting function
to the data, the resulting quadratic equation is solved for f'. This f'
is then Kramers-Kronig transformed to obtain a corresponding f''. With
these new values for f' and f'', the data is refit to obtain new values
of
, etc., and in turn a new value for f'. This
process usually converges after three or four iterations.
The iterative Kramers-Kronig method has several advantages. First, little knowledge of the crystal structure is required to obtain the f' and f'' functions. Second, the iterative method properly accounts for the diffracted intensity's dependence on the real and imaginary parts of the anomalous amplitude, and also properly accounts for its dependence on the square of the fine structure. Note that the direct method for isolating the fine structure, presented in the previous subsection, neglected the square of the fine structure.
