Energy shift in exported data
Hello, I have noticed the following behavior in Athena 0.9.20 on OSX 10.8.5. If a group with an energy shift applied is exported as norm(E) using the export marked groups option then the energy shift is not preserved in the .nor file. If the export current group option is used then the energy shift is preserved. This seems to be general behavior and should be straightforward to reproduce, but I can provide an example project if needed. Thank you, George
On 07/11/2014 06:56 PM, George Sterbinsky wrote:
Hello,
You are correct. Yikes! I will try to get that fixed soon enough that Frank can get the fix into the next demeter-devel release for Mac. Thanks, B -- Bruce Ravel ------------------------------------ bravel@bnl.gov National Institute of Standards and Technology Synchrotron Science Group at NSLS --- Beamlines U7A, X24A, X23A2 Building 535A Upton NY, 11973 Homepage: http://xafs.org/BruceRavel Software: https://github.com/bruceravel
participants (2)
Bruce Ravel -
George Sterbinsky
