Re: [Ifeffit] posting to the ifeffit mailing list
Hello Bruce Ravel I have another questions. I got the charge transfer of TiO2 from FEFF8 as following;Ti: (not absorber) Charge transfer : 0.556 Electron counts for each orbital momentum: 0 0.408 1 6.678 2 2.350 3 0.000O: Charge transfer : -0.280 Electron counts for each orbital momentum: 0 1.843 1 4.354 2 0.087 3 0.000It is known that the electron number of Ti atom ( the atomic number 22) is 1s^2 2s^2 2p^6 3s^2 3p^6 4s^2 3d^2. In the results of FEFF, 0 is s orbital, 1 is p orbital so on.. right? as you know, there is each s-orbital or p-orbital in principal quantum number.which orbital momentum of principle quantum number does 0, 1, 2 and 3 mean? second I cant understand electron counts. I thought that Charge transfer was calculated by electron counts for each orbital momentum, comparing the electron counts of free atom.So I tried to calculate like this: In free oxygen atom case, 2^s has 2 electron, 2^p! has 4 electron. The electron counts calculated by FEFF8 is 1.843 + 4.354 + 0.087 =6.284So charge transfer is 6 - 6.284 = 0.284 The charge thransfer, 0.284, obtained from my calculation is different from the value of FEFF8. How can I get charge transfer form electron counts?
From: bravel@bnl.gov> To: eunsuk1986@hotmail.com> Subject: posting to the ifeffit mailing list> Date: Mon, 5 Jan 2009 17:10:31 -0500> > > Hi Jeong,> > I think I know what went wrong with your post to the mailing list from last > Friday. I think that you (for some reason) sent the mail to> ifeffit-bounces@millenia.cars.aps.anl.gov> rather than to> ifeffit@millenia.cars.aps.anl.gov> > The second address is the normal point of entry to the mailing list. The > other address is part of the mailing list administration. I am not sure how > you ended up sending email there. Weird. If you make sure to send your mail > to the second address, it should get posted without any problems.> > If you do have any problems posting to the mailing list, I will probably be > notified automatically. But if you attempt to send mail to the mailing list > and have any problems, please let me know as soon as possible so I can try to > correct the problem.> > Regards,> B> > -- > > Bruce Ravel -------! ----------------------------- bravel@bnl.gov> > National Institute of Standards and Technology> Synchrotron Methods Group at NSLS --- Beamlines U7A, X24A, X23A2> Building 535A> Upton NY, 11973> > My homepage: http://xafs.org/BruceRavel> EXAFS software: http://cars9.uchicago.edu/~ravel/software/exafs/
블로그에 윈도우 라이브 메신저(베타)를 홍보하면 선물을 드립니다! http://windowslive.msn.co.kr/wlm/customer/view.asp?sectionDiv=2&seq=272
Jeong, Your questions are of the sort that I always wish the folks working on Feff8 would volunteer an answer for, but I will do what I can.
I have another questions. I got the charge transfer of TiO2 from FEFF8 as following; Ti: (not absorber) Charge transfer : 0.556 Electron counts for each orbital momentum: 0 0.408 1 6.678 2 2.350 3 0.000 O: Charge transfer : -0.280 Electron counts for each orbital momentum: 0 1.843 1 4.354 2 0.087 3 0.000
It is known that the electron number of Ti atom ( the atomic number 22)&nbs! p;is 1s^2 2s^2 2p^6 3s^2 3p^6 4s^2 3d^2.
Yes, but Feff8 is just considering the valence electrons. The core electrons are not included in those counts.
That is correct. The number in the left column is the angular momentum quantum number.
as you know, there is each s-orbital or p-orbital in principal quantum number. which orbital momentum of principle quantum number does 0, 1, 2 and 3 mean?
To the best of my knowledge, Feff8 does not make that clear. For most elements, it considers the valence electrons of a particular angular momentum to be the highest lying ones. See the subroutine corval contained in the file POT/corval.f in the Feff8 source tree for more details.
second I cant understand electron counts. I thought that Charge transfer was calculated by electron counts for each orbital momentum, comparing the electron counts of free atom. So I tried to calculate like this: In free oxygen atom case, 2^s has 2 electron, 2^p has 4 electron. The electron counts calculated by FEFF8 is 1.843 + 4.354 + 0.087 =6.284 So charge transfer is 6 - 6.284 = 0.284 The charge thransfer, 0.284, obtained from my calculation is different from the value of FEFF8. How can I get charge transfer form electron counts?
I think the problem is that you are not considering the stoichiometry (or the relative number of Ti and O atoms used in the calculation (see http://leonardo.phys.washington.edu/feff/wiki/index.php?title=POTENTIALS, otherwise it is determined from the contents of the cluster). HTH, B -- Bruce Ravel ------------------------------------ bravel@bnl.gov National Institute of Standards and Technology Synchrotron Methods Group at NSLS --- Beamlines U7A, X24A, X23A2 Building 535A Upton NY, 11973 My homepage: http://xafs.org/BruceRavel EXAFS software: http://cars9.uchicago.edu/~ravel/software/exafs/
participants (2)
Bruce Ravel -
JeongEunSuk
