20 Feb
20 Feb
'04
11:37 a.m.
Peter, Of course, the bottom line is that the k-weight shouldn't affect the values of the parameters Ifeffit finds. If it does, it's a sign that the parameters should not be trusted. Often, this happens when the k-range chosen to fit is inappropriate (extends up into a range where the data is dominated by noise, down into a range where the background is poorly chosen, or across a small edge due to a contaminant, for example). I always test my "final" fits at all three k-weights separately to make sure the values of the parameters stay fairly stable. --Scott Calvin Sarah Lawrence College
7975
Age (days ago)
7975
Last active (days ago)
0 comments
1 participants
participants (1)
SCalvin100@aol.com
