Issue about plotting simulated EXAFS in Larix
Dear Matt, I am trying to simulate a theoretical EXAFS with a DFT calculated CIF file via Larix. I performed a FEFF calculation on the CIF file and imported a path to the FEFF fitting panel. However, I didn't get any results when I clicked on the "Plot Current Model" bottom. I get the following error message: TypeError: unsopported format string passed to NoneType.__format__. Could you please help me? Thank you in advance. Best regards, Aowen
Hi Aowen,
Sorry for the trouble. I think you are seeing a “known but not-yet solved” problem. The Feffit Panel in Larix needs to have an experimental data set to show a simulated EXAFS spectrum. That should not be necessary, but it is for now to work around this bug.
This is on the list of things to fix, but I did not get to it before the most recent release.
--Matt
Dear Matt,
Thank you very much for your reply! I think this is enough for my analysis now.
Best regards,
Aowen
-----Original Messages-----
participants (2)
AowenLi -
Matthew Newville
