Hello, I'm running Athena (Demeter 0.9.20) with Ubuntu 12.04 LTS. Every time I go to the 'align data' window (with data open), Athena closes and the following message appears in the terminal: Usage: Wx::ComboBox::GetClientData(THIS, n) at /home/dave/perl5/lib/perl5/x86_64-linux-gnu-thread-multi/Demeter/UI/Athena/Align.pm line 161, <F> line 1. Any suggestions on how to fix this problem. Thanks, Dave -- ----------------------------------------------------- Dr Dave Pickup School of Physical Sciences Ingram Building University of Kent Canterbury CT2 7NH Tel. 01227 823276 Fax. 01227 827558
One of the small programs installed with demeter is called "denv". Could you run that and cut-n-paste the output? B On 04/10/2014 06:27 AM, David Pickup wrote:
Hello,
Thanks, Dave
-- Bruce Ravel ------------------------------------ bravel@bnl.gov National Institute of Standards and Technology Synchrotron Science Group at NSLS --- Beamlines U7A, X24A, X23A2 Building 535A Upton NY, 11973 Homepage: http://xafs.org/BruceRavel Software: https://github.com/bruceravel
Thanks Bruce. Here you go: Demeter 0.9.20 with perl 5.014002 on linux using Ifeffit 1.2.11d Major modules version ================================================== Ifeffit ....................... 3.0.1 Moose ......................... 2.1204 MooseX::Aliases ............... 0.11 MooseX::Types ................. 0.44 Archive::Zip .................. 1.37 Capture::Tiny ................. 0.24 Chemistry::Elements ........... 1.07 Config::INI ................... 0.023 Const::Fast ................... 0.014 DateTime ...................... 1.08 Graph ......................... 0.96 Graphics::GnuplotIF ........... 1.7 Math::Round ................... 0.06 Pod::POM ...................... 0.29 PDL ........................... 2.007 PDL::Stats .................... 0.6.5 Regexp::Assemble .............. 0.35 Regexp::Common ................ 2011121001 Heap::Fibonacci ............... 0.80 Math::Random .................. 0.71 Text::Template ................ 1.45 Tree::Simple .................. 1.23 YAML::Tiny .................... 1.50 On 10/04/14 12:23, Bruce Ravel wrote:
B
Hello,
Thanks, Dave
participants (2)
Bruce Ravel -
David Pickup
