Kapton in glove box
Hi Todd, I've taken the liberty of posting your question to the Ifeffit mailing list. You're likely to get more accurate and quicker answers to these kinds of questions there. (For the rest of you: Todd is asking about the technique of preparing air-sensitive samples in a glove box, putting them on Kapton tape, sealing them in plastic bags, and transporting them to the beamline, shooting right through the bags.) I'll take my shots, though: It's hard for me to imagine adsorbed oxygen on the Kapton being more significant than the other sources of stray oxygen that can be present in a glove box. After all, the Kapton's in there too. And I don't think it's going to be more significant than the oxygen that diffuses through the plastic bags during transport. The thinner the Kapton tape, the better, as that will minimize the absorption due to the tape. It used to be hard to find 1 mil Kapton tape with adhesive, but now it's easy. Hephaestus will give you the absorption of Kapton, so you can judge how big an effect it will be at the energies at which you'll work. --Scott Calvin Sarah Lawrence College On Aug 4, 2009, at 2:39 PM, Monson, Todd wrote:
Scott,
Thanks. Is it pretty reasonable to assume that the kapton tape that you put your samples on doesn’t have any adsorbed oxygen that could affect your samples? Do you do anything to clean the kapton? Where are some good places to buy the kapton (and do you need to purchase rather thin kapton tape for doing XAFS)?
Thanks again,
Todd
From: Scott Calvin Sent: August 04, 2009 11:34 AM To: Monson, Todd Cc: Scott Calvin Subject: Re: mossbauer
Hi Todd,
Regular zip-loc bags work just fine. For heat sealers I've used everything from a heat sealer manufactured for the purpose to a little propane torch--even a cigarette lighter should work. Putting one sealed bag inside another, if the energy you're working at allows it, seems to work quite well.
--Scott
On Aug 4, 2009, at 1:15 PM, Monson, Todd wrote:
Scott,
I had another question – what kind of plastic bags and heat sealers do you use for sealing up your air-sensitive XAFS samples? And where could I buy them?
Todd
Todd,
Are you working with oxygen sensitive or moisture sensitive samples (or
both)? If it's just moisture sensitive, then you can use regular 2-sided
tape from your local office supply and polypropylene film to seal samples in
polycarbonate or aluminum holders (or even pellets if you're lucky enough to
be able to press pellets that hold their shape). Chemplex Industries is
where I have gotten the polypropylene films I have used (and Kapton as well
- www.findtape.com also has a good selection of Kapton tape).
I used this method with many samples that involved heavily chlorided
titanium on silica and had few problems if they're used within 5-7 days
after packing in a glove box (the samples with problems resulted from
improperly sealed samples). You can get jars (baby food jars work very well
to ship individual samples) to store the samples for shipping and if you
pack the jars in the glove box, you will have the box atmosphere in the
jars, for a little while anyway.
A note on oxygen sensitivity (and to an extent moisture sensitivity): you
probably already know this, but I'll say it anyway...if cardboard is present
in the role of Kapton tape, you may have oxygen/water diffusion from the
cardboard for a few days after you take it into the box. Our rule of thumb
was to pull vacuum on anything involving cardboard for at least 48 hrs
before taking it into the box. All that to say, take your supplies into the
box a few days ahead of time to allow your box catalyst to take care of any
residual oxygen/water that make their way in.
HTH,
-Richard
On Wed, Aug 5, 2009 at 7:27 PM, Scott Calvin
Scott,
Thanks again,
Todd
*From:* Scott Calvin *Sent:* August 04, 2009 11:34 AM *To:* Monson, Todd *Cc:* Scott Calvin *Subject:* Re: mossbauer
Hi Todd,
--Scott
Scott,
Todd
_______________________________________________ Ifeffit mailing list Ifeffit@millenia.cars.aps.anl.gov http://millenia.cars.aps.anl.gov/mailman/listinfo/ifeffit
Good point on the cardboard, Richard. I always pre-cut strips of Kapton tape, so that I wasn't bringing in cardboard at all. --Scott Calvin Sarah Lawrence College On Aug 5, 2009, at 8:13 PM, Richard Mayes wrote:
Todd,
Are you working with oxygen sensitive or moisture sensitive samples (or both)? If it's just moisture sensitive, then you can use regular 2-sided tape from your local office supply and polypropylene film to seal samples in polycarbonate or aluminum holders (or even pellets if you're lucky enough to be able to press pellets that hold their shape). Chemplex Industries is where I have gotten the polypropylene films I have used (and Kapton as well - www.findtape.com also has a good selection of Kapton tape).
I used this method with many samples that involved heavily chlorided titanium on silica and had few problems if they're used within 5-7 days after packing in a glove box (the samples with problems resulted from improperly sealed samples). You can get jars (baby food jars work very well to ship individual samples) to store the samples for shipping and if you pack the jars in the glove box, you will have the box atmosphere in the jars, for a little while anyway.
A note on oxygen sensitivity (and to an extent moisture sensitivity): you probably already know this, but I'll say it anyway...if cardboard is present in the role of Kapton tape, you may have oxygen/water diffusion from the cardboard for a few days after you take it into the box. Our rule of thumb was to pull vacuum on anything involving cardboard for at least 48 hrs before taking it into the box. All that to say, take your supplies into the box a few days ahead of time to allow your box catalyst to take care of any residual oxygen/water that make their way in.
HTH, -Richard
Dear Todd, The use of Kapton sticky tape for ambient-sensitive samples works quite well. We usually transport samples from our lab in Ar-filled schlenk flasks, and press the pellets in the glove box at Hasylab (see also Darek's reply). In my experience, Kapton tape sufficiently protects the sample for one or two days. After that, oxygen diffusion can be noticed in the spectra. Best wishes, Maurits. Scott Calvin wrote:
Todd,
Are you working with oxygen sensitive or moisture sensitive samples (or both)? If it's just moisture sensitive, then you can use regular 2-sided tape from your local office supply and polypropylene film to seal samples in polycarbonate or aluminum holders (or even pellets if you're lucky enough to be able to press pellets that hold their shape). Chemplex Industries is where I have gotten the polypropylene films I have used (and Kapton as well - www.findtape.com http://www.findtape.com also has a good selection of Kapton tape).
HTH, -Richard
-- Dr. M.W.E. van den Berg Ruhr Universitaet Bochum Lehrstuhl fuer Technische Chemie Gebaeude NBCF-Sued 04/686 Universitaetsstrasse 150 44780 Bochum Germany Tel.: +49-234-3226907 Fax: +49-234-3214115 E-mail: Maurits.vandenberg@techem.rub.de
Dear Todd, Dears Alls, in my lab (Hasylab) many EXAFS users use the glovebox to prepare "air sensitive" samples. We do not know a lot about your samples, but I can say from practical aspect, that in the most cases the sample preperation in the glove box and then closing it in the Kapton tape is sufficient. Some of the users like one side adhesive Kapton dots, which fits to the size of pelets we use (in our case it is 13 mm of diameter). Some of the users use also plastic bags mounted in the glove box on the sample holder to avoid the sample contact with air during the transport to experiment area. I have also one comment - be aware of some Kaptons - I found that some of them contain a lot of trace elements. best regards darek -----Original Message----- From: ifeffit-bounces@millenia.cars.aps.anl.gov [mailto:ifeffit-bounces@millenia.cars.aps.anl.gov] On Behalf Of Scott Calvin Sent: Thursday, August 06, 2009 1:27 AM To: Todd Monson; XAFS Analysis using Ifeffit Subject: [Ifeffit] Kapton in glove box Hi Todd, I've taken the liberty of posting your question to the Ifeffit mailing list. You're likely to get more accurate and quicker answers to these kinds of questions there. (For the rest of you: Todd is asking about the technique of preparing air-sensitive samples in a glove box, putting them on Kapton tape, sealing them in plastic bags, and transporting them to the beamline, shooting right through the bags.) I'll take my shots, though: It's hard for me to imagine adsorbed oxygen on the Kapton being more significant than the other sources of stray oxygen that can be present in a glove box. After all, the Kapton's in there too. And I don't think it's going to be more significant than the oxygen that diffuses through the plastic bags during transport. The thinner the Kapton tape, the better, as that will minimize the absorption due to the tape. It used to be hard to find 1 mil Kapton tape with adhesive, but now it's easy. Hephaestus will give you the absorption of Kapton, so you can judge how big an effect it will be at the energies at which you'll work. --Scott Calvin Sarah Lawrence College On Aug 4, 2009, at 2:39 PM, Monson, Todd wrote: Scott, Thanks. Is it pretty reasonable to assume that the kapton tape that you put your samples on doesn't have any adsorbed oxygen that could affect your samples? Do you do anything to clean the kapton? Where are some good places to buy the kapton (and do you need to purchase rather thin kapton tape for doing XAFS)? Thanks again, Todd From: Scott Calvin Sent: August 04, 2009 11:34 AM To: Monson, Todd Cc: Scott Calvin Subject: Re: mossbauer Hi Todd, Regular zip-loc bags work just fine. For heat sealers I've used everything from a heat sealer manufactured for the purpose to a little propane torch--even a cigarette lighter should work. Putting one sealed bag inside another, if the energy you're working at allows it, seems to work quite well. --Scott On Aug 4, 2009, at 1:15 PM, Monson, Todd wrote: Scott, I had another question - what kind of plastic bags and heat sealers do you use for sealing up your air-sensitive XAFS samples? And where could I buy them? Thanks, Todd
participants (4)
Maurits van den Berg -
Richard Mayes -
Scott Calvin -
Zajac, Dariusz A.
