Re: [Ifeffit] [FEFF8.4] Re(x) is .le. zero in besjn
Hi Mauro, This is probably a bug in feff. There is probably a workaround. Can you send your feff.inp file and I will try to help find the right cards to make your file run. Also I will add this to a list of bugs to look at. Cheers, Josh
Message: 1 Date: Mon, 01 Oct 2007 18:17:50 +0200 From: Mauro Rovezzi
Subject: [Ifeffit] [FEFF8.4] Re(x) is .le. zero in besjn ? To: Ifeffit-ML Message-ID: <47011DAE.2010508@esrf.fr> Content-Type: text/plain; charset=ISO-8859-1 Hi all,
A little question about a FEFF8 error message I have and I cannot understand what it means :
This error is generated when I try to add the SCF to an EXAFS calculation on MnO (manganosite) and the SCF iteration is at step 9 of 30.
Seen that the cards in the feff.inp file are properly used (I normally run SCF in EXAFS calculations) do you have any idea of what is going on?
Thanks for your help, as usual!
Mauro
-- Mauro Rovezzi
PhD student - GILDA BM08 c/o ESRF (Grenoble, FR) ------------------------------
_______________________________________________ Ifeffit mailing list Ifeffit@millenia.cars.aps.anl.gov http://millenia.cars.aps.anl.gov/mailman/listinfo/ifeffit
End of Ifeffit Digest, Vol 56, Issue 1 **************************************
The attached FEFF8 input file works fine with FEFF8.2 and FEFF8.4
compiled on a 64 bit Linux machine and fails on my 32 bit PC. I suppose
that this odd behavior is due to different Fortran compilers used. In
fact, in the first case was used Intel compiler and in the second the
GNU one. I think this kind of problems with Fortran compilers are
frequent so I don't think is a real bug of the FEFF8 code.
M.
Mauro Rovezzi
participants (2)
joshua jason kas -
Mauro Rovezzi
