An Example of Data File
VERSION: 3.1
ELEMENTS: 1
DATE:
CHANNELS: 2048
ROIS: 6
REAL_TIME: 300.0000000
LIVE_TIME: 298.6300049
CAL_OFFSET: 1.8733252e+001
CAL_SLOPE: 5.8587302e-002
CAL_QUAD: 0.0000000e+000
TWO_THETA: 5.4373522
ROI_0_LEFT: 632
ROI_0_RIGHT: 672
ROI_0_LABEL: gold 111 &
ROI_1_LEFT: 783
ROI_1_RIGHT: 823
ROI_1_LABEL: gold 200 &
ROI_2_LEFT: 1248
ROI_2_RIGHT: 1288
ROI_2_LABEL: gold 220 &
ROI_3_LEFT: 1522
ROI_3_RIGHT: 1562
ROI_3_LABEL: gold 311 &
ROI_4_LEFT: 1605
ROI_4_RIGHT: 1645
ROI_4_LABEL: gold 222 &
ROI_5_LEFT: 1905
ROI_5_RIGHT: 1945
ROI_5_LABEL: gold 400 &
ENVIRONMENT:
13BMD:OperatorName.VAL="Andrew Campbell, Uchi, Yanbin" (Operator
Name)
ENVIRONMENT:
13BMD:SampleName.VAL="Fe-Ru (15 wt%) T0324" (Sample Name)
ENVIRONMENT:
13BMD:ExperimentComment1.VAL="" (Experiment Comment1)
ENVIRONMENT:
13BMD:ExperimentComment2.VAL="" (Experiment Comment2)
ENVIRONMENT:
13BMD:ExperimentComment3.VAL="" (Experiment Comment3)
ENVIRONMENT:
13BMD:ExperimentComment4.VAL="" (Experiment Comment4)
ENVIRONMENT:
13BMD:ExperimentComment5.VAL="" (Experiment Comment4)
ENVIRONMENT:
13BMD:DMM1Ch1_calc.VAL="34.9353" (Pressure in tons)
ENVIRONMENT:
13BMD:DMM1Ch2_calc.VAL="89.8025" (unused)
ENVIRONMENT:
13BMD:DMM1Ch3_calc.VAL="0.0000" (Ram height in mm)
ENVIRONMENT:
13BMD:DMM1Ch4_calc.VAL="-12.2329" (unused)
ENVIRONMENT:
13BMD:DMM1Ch5_calc.VAL="0.0000" (Thermocouple emf1)
ENVIRONMENT:
13BMD:DMM1Ch6_calc.VAL="-10.8000" (Thermocouple emf2)
ENVIRONMENT:
13BMD:DMM1Ch7_calc.VAL="15.7447" (unused)
ENVIRONMENT:
13BMD:DMM1Ch8_calc.VAL="-1.1527e+147" (unused)
ENVIRONMENT:
13BMD:DMM1Ch9_calc.VAL="900.2378" (Unused)
ENVIRONMENT:
13BMD:DMM1Ch10_calc.VAL="0.0000" (Sample T (C))
ENVIRONMENT: 13BMD:DMM2Ch1_calc.VAL="3.9899"
(Heater Voltage (AC Volt))
ENVIRONMENT:
13BMD:DMM2Ch6_calc.VAL="32.6642" (Heater current (AC amps))
ENVIRONMENT:
13BMD:LVP_furnace_calcs.C="0.122" (Heater resistance (Ohms))
ENVIRONMENT:
13BMD:LVP_furnace_calcs.D="130.328" (Heater power (Watts))
ENVIRONMENT:
S:SRcurrentAI.VAL="102.415" (Ring current)
ENVIRONMENT:
13BMD:m1.RBV="-31.580" (Press upstream Y)
ENVIRONMENT:
13BMD:m2.RBV="-31.580" (Press inboard Y)
ENVIRONMENT:
13BMD:m3.RBV="-31.580" (Press downstream Y)
ENVIRONMENT: 13BMD:m4.RBV="-8.572"
(Press upstream X)
ENVIRONMENT:
13BMD:m5.RBV="-8.226" (Press inboard X)
ENVIRONMENT:
13BMD:m6.RBV="-18.463" (Press Z drive)
ENVIRONMENT:
13BMD:m7.RBV="0.000" (Vertical LVP front slit Y position)
ENVIRONMENT:
13BMD:m8.RBV="0.000" (Horizontal LVP front slit X positon)
ENVIRONMENT:
13BMD:m9.RBV="35.508" (Detector X)
ENVIRONMENT:
13BMD:m10.RBV="-7.861" (Detector Z)
ENVIRONMENT:
13BMD:m16.RBV="50.738" (Detector Y)
ENVIRONMENT:
13BMD:m12.RBV="4.575" (Detector Two Theta)
ENVIRONMENT:
13BMD:m13.RBV="-3.235" (Detector Phi)
ENVIRONMENT:
13BMD:m11.RBV="-0.000" (CCD Stage X)
ENVIRONMENT:
13BMD:m14.RBV="172.021" (CCD Stage Y)
ENVIRONMENT:
13BMD:m15.RBV="114.000" (CCD Stage Z)
ENVIRONMENT:
13BMD:m29.RBV="-4.920" (Inboard hutch slit)
ENVIRONMENT:
13BMD:m30.RBV="-1.920" (Outboard hutch slit)
ENVIRONMENT:
13BMD:m31.RBV="3.500" (Top hutch slit)
ENVIRONMENT:
13BMD:m32.RBV="0.500" (Bottom hutch slit)
DATA:
6
6
3
0
1
2
0
6
5
5
0
5
0
0
0
2
0
1
1
0
2
1
4
1
3
0
2
4
0
2
2
2
1
1
3
3
1
1
3
1
2
2
1
0
1
0
1
5
3
9
3
1
1
2
0
2
2
1
8
1
1
0
3
1
3
1
2
2
2
0
1
1
2
0
3
1
2
1
3
1
0
1
1
3
2
2
0
1
1
2
2
2
6
1
1
8
3
2
4
3
3
2
1
4
1
4
1
2
2
5
3
2
2
2
1
2
0
0
2
1
3
2
2
3
2
4
2
0
0
2
1
3
0
3
1
2
1
2
2
2
1
5
2
0
2
1
3
4
3
2
1
1
4
3
2
1
0
4
5
2
0
1
0
2
4
1
2
1
1
1
4
0
2
3
2
4
2
3
1
1
2
3
0
1
2
0
1
2
2
2
2
2
1
0
3
2
1
3
1
4
4
4
5
5
2
3
1
1
3
4
1
2
4
1
5
2
2
0
1
3
2
4
3
4
5
7
4
3
3
3
4
4
3
2
5
1
2
7
1
0
3
0
3
2
4
6
3
3
4
0
1
8
4
2
6
5
3
4
5
1
5
3
2
2
3
5
5
4
5
3
3
6
0
2
5
4
3
4
7
4
3
6
7
7
4
4
4
4
6
2
3
5
4
7
4
3
3
5
7
9
5
2
2
2
7
3
8
5
6
5
3
2
4
4
8
8
5
2
9
7
7
9
10
14
18
17
19
26
21
14
21
15
12
15
6
6
4
8
8
8
5
12
7
6
5
6
8
5
7
7
9
4
6
2
10
6
4
11
7
8
12
6
11
4
7
8
4
10
3
12
6
3
7
10
6
7
13
4
4
6
1
5
10
8
7
8
12
5
10
9
12
10
7
14
10
16
11
13
11
7
9
15
7
12
9
11
10
8
5
8
8
7
11
5
13
12
8
9
13
15
10
10
9
14
11
6
13
6
12
10
9
9
10
15
7
15
8
6
16
9
15
11
13
12
11
18
15
13
6
7
8
18
10
18
7
12
13
15
18
14
19
10
10
9
14
13
14
14
18
21
15
14
10
18
16
17
19
13
16
14
14
10
10
20
17
23
16
13
14
19
11
20
17
26
15
18
20
19
18
27
22
11
22
18
15
28
19
15
28
24
28
30
27
15
22
26
23
21
19
12
16
18
27
29
21
20
35
22
19
18
21
17
24
22
22
20
33
24
20
29
21
21
16
28
26
19
39
30
27
31
29
24
23
26
34
35
32
43
46
74
69
102
131
147
158
171
128
118
98
70
62
45
52
36
30
42
31
30
37
30
57
78
100
146
207
276
306
289
290
285
224
172
143
105
86
52
55
44
43
42
26
34
36
29
23
27
27
28
39
36
29
19
33
22
35
27
26
31
39
28
42
46
47
50
63
91
68
81
91
81
77
77
40
45
39
25
41
37
31
38
37
36
35
36
45
23
24
33
38
32
37
37
38
49
26
27
30
35
38
22
31
21
43
34
26
35
31
66
70
91
135
199
242
307
363
450
421
374
367
297
287
183
131
103
78
60
50
31
35
28
39
37
43
35
46
42
38
36
31
31
32
36
42
35
38
29
37
34
41
27
33
32
35
34
28
42
41
44
40
66
92
151
211
339
441
518
524
555
492
428
338
261
194
135
132
105
119
159
152
194
237
314
391
368
421
437
394
389
378
271
231
156
128
112
83
101
111
139
151
175
156
184
179
152
117
111
94
86
75
61
70
66
68
69
67
51
48
43
29
41
31
36
29
29
35
38
39
45
46
52
46
41
52
52
47
53
60
44
49
106
137
173
272
434
579
803
1016
1216
1356
1435
1409
1389
1276
994
853
589
405
284
182
155
72
49
40
41
47
36
39
27
26
22
38
23
27
39
28
30
29
24
22
28
24
20
22
31
26
25
23
20
24
27
25
17
25
32
25
22
21
20
20
25
22
29
24
27
23
23
18
23
23
18
21
18
23
21
20
19
20
16
17
19
10
15
16
22
18
21
24
16
19
27
27
22
14
16
22
17
24
24
22
23
22
22
24
29
24
26
21
35
18
16
19
10
12
18
14
17
13
14
17
15
13
15
9
13
16
14
17
9
21
14
17
15
7
11
16
18
15
11
12
16
9
8
20
22
14
14
9
17
17
18
11
12
13
18
10
13
7
9
9
14
17
24
12
20
15
11
14
13
23
24
32
38
48
39
48
43
35
43
42
50
40
27
21
18
29
16
21
10
17
17
16
17
10
22
15
9
9
16
11
7
21
13
9
12
8
14
12
9
12
12
11
15
17
15
7
6
12
10
13
8
10
17
11
13
15
9
14
3
11
6
7
6
17
7
10
17
12
9
18
12
14
2
9
12
10
13
15
9
7
13
13
9
10
12
13
6
14
18
13
16
11
14
11
7
4
10
4
9
13
11
2
8
16
14
14
11
9
16
12
20
21
25
34
46
43
48
46
64
71
59
63
61
46
53
33
32
32
19
21
9
18
15
10
12
7
10
13
9
10
12
8
8
7
10
10
8
7
11
9
8
11
13
10
14
12
12
20
14
16
12
22
31
33
47
51
59
81
70
70
76
71
81
56
48
39
30
35
33
23
15
18
14
13
20
23
28
33
36
45
52
45
63
51
51
62
63
49
30
31
32
17
14
13
17
22
9
11
12
11
16
14
7
7
4
11
10
6
10
11
14
7
3
9
13
11
6
4
9
1
8
5
5
7
9
4
9
5
5
11
11
6
8
10
7
8
2
6
6
9
8
12
11
5
4
15
4
8
6
9
4
4
5
7
7
10
7
6
8
5
8
10
9
5
10
2
8
6
7
7
4
6
11
10
2
7
4
7
5
6
9
7
9
7
11
6
11
1
9
4
6
6
7
9
9
12
10
2
5
10
10
15
15
12
18
13
20
9
14
16
19
13
8
13
11
6
5
13
7
5
8
4
8
5
7
6
4
5
6
6
5
4
2
9
14
11
18
12
15
11
18
14
16
11
15
12
9
13
6
6
6
8
10
3
4
7
8
6
8
8
6
8
3
4
6
3
5
2
11
7
3
6
1
6
2
5
5
5
7
3
6
7
5
4
5
5
4
8
8
3
4
10
5
3
13
8
4
3
6
9
3
8
2
1
5
10
1
3
4
9
3
3
8
7
4
10
9
14
18
17
25
19
19
19
34
21
24
29
29
35
36
16
31
28
15
19
28
17
15
17
20
14
15
7
9
10
7
8
5
7
6
4
4
7
4
5
4
7
6
4
5
3
6
2
2
4
6
3
3
6
3
4
3
4
5
6
2
1
6
8
5
1
9
7
3
2
1
4
4
5
4
0
2
1
2
2
7
4
5
3
6
2
4
6
3
3
2
4
6
4
5
6
8
12
12
8
7
11
7
11
5
7
9
17
7
8
7
9
5
3
6
2
4
4
6
5
4
4
6
1
3
4
4
3
1
4
1
5
5
5
3
2
1
0
4
9
2
2
1
3
2
7
4
4
2
1
0
4
2
2
6
2
4
5
8
8
5
4
5
5
9
15
22
16
15
13
14
10
15
10
12
5
8
7
6
5
6
5
3
4
3
5
4
2
1
2
5
2
3
2
4
0
1
5
4
2
2
1
2
1
4
4
1
0
3
4
0
1
4
1
0
1
0
5
1
4
2
4
1
6
0
4
4
2
4
3
4
4
1
0
4
4
1
3
1
2
3
3
3
3
2
1
2
3
2
2
2
0
2
2
3
1
6
4
1
1
2
2
3
1
0
3
3
3
2
4
1
4
5
5
3
1
4
2
4
7
5
3
5
5
8
4
3
2
3
1
1
3
1
1
4
1
1
4
1
0
1
3
3
3
7
4
10
6
8
7
10
8
13
9
6
6
6
10
6
7
6
5
4
3
4
2
4
3
0
3
3
2
3
4
1
0
2
2
2
2
3
0
4
9
9
5
7
8
3
6
3
7
6
3
6
2
4
2
1
2
1
0
1
1
0
2
2
0
0
0
1
2
2
1
5
4
4
1
1
0
0
1
3
2
2
3
0
0
0
0
1
2
0
2
3
3
0
1
1
2
3
0
2
4
3
2
0
2
0
1
2
0
0
2
0
1
4
2
2
0
0
3
0
2
0
2
1
2
0
2
0
1
0
2
1
1
2
1
1
2
0
1
0
0
4
2
2
0
1
0
3
1
1
1
1
1
0
1
2
1
2
2
1
1
0
3
1
0
2
2
0
0
0
2
0
0
1
1
0
1
1
1
0
0
4
3
3
2
1
0
1
1
0
2
0
0
0
2
0
2
0
1
1
3
1
1
1
0
0
2
0
0
1
0
1
0
1
0
1
0
0
0
1
1
1
3
0
0
0
0
0
0
1
1
0
0
1
1
3
0
2
2
1
1
2
2
1
0
1
0
2
4
2
1
3
1
2
1
0
0
0
1
0
0
0
2
2
0
0
0
1
1
1
2
1
0
0
0
0
0
0
0
0
0
3
0
0
0
0
0
1
0
0
0
1
0
0
0
1
0
2
1
0
0
0
0
0
0
0
1
0
0
0
0
1
1
0
0
0
0
2
2
0
0
0
0
0
3
3
1
1
2
1
0
1
0
1
2
1
1
0
1
1
1
1
1
0
0
1
0
2
0
0
