Mr. Rehr,
Just to make sure, by 'ldos00.dat' file you actually mean 'rholNN.dat' files? The FEFF8 manual does not mention any 'ldos00.dat' file, and 'rholNN.dat' files are the output files of the LDOS card.
Thank you,
Lydia Nemirovsky
Dear Lydia,
I am employing FEFF8 to do XANES calculations, using SCF and LDOS cards among others. I was wondering how to weight the local density of states appropriately to compare it to the spectroscopic data. What cross-section should I use, or are cross-sections already embedded in the program?
You can compare the LDOS with the XAS, e.g., for K-shell XAS by plotting the XAS from xmu.dat using cols 2 (E-E0) and 4 (mu) against the LDOS from ldos00.dat using e.g., col 1 (E-E0) vs col 3 (pDOS). Cheers, John Rehr |
