[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
forgot attachment
Dear Prof Rehr,
I have been having fun playing with your code but...... now I
desperately need to get some results, so I was wondering of you could help
me.
For some time now I have been trying to carry out calculations using
feff82 to simulate my experimental data of Mn K-edge x-ray absorption and
XMCD for the dilute ferromagnetic semiconductor system GaMnAs. So far I have
been deluding myself that I have been doing everything correctly since the
theoretical spectra compared well with the experimental XAS and, in the low
energy region, with the XMCD. However on closer inspection of the output
files (why I did not do this from the start I do not know) I have come to
think that the good agreement is fortuitous. My problem lies with the issues
of charge transfer, the high Fermi level and the electronic configuration.
Following advice you have given to others I carried out a ground state
calculation by using the NOHOLE option and included a large number of atoms
in my cluster (100 atoms). (I have attached the files to this email). I
would expect that the charge transfer on the Mn atom to be positive, a Fermi
level to be in the middle of the Mn d-states and the Ga and As 3d states not
to be involved at all in the valence region. In another attempt i edited
ival for Ga and removed the 3d states from the valence states and recompiled
the code and ran it again only to find that the d states present again the
calculated l-projected DOS. Where do you think I am going wrong?
does it make sense to limit l_fms when defining the potentials to include
only s and p states?
should the cluster size be much larger?
Thanking you in advance for your help
Tarnjit
<PRE>
+ -- Warning text added to this message by -- +
+ -- University of Washington Computing & Communications -- +
+ -- help@cac.washington.edu -- +
+ ATTACHMENTS DELETED +
+ One or more attachments have been deleted from this message +
+ by UW C&C because they are of a file type currently being +
+ used by attackers to try to get viruses onto UW computers. +
+ o If the sender of the message is known to you, and you were +
+ expecting the attachments, you will need to make arrangements +
+ with the sender to receive the attachments by other means or +
+ have the attachments resent after changing the file names. +
+ For a list of offending file names, see +
+ http://www.washington.edu/computing/alerts/attachblock.html +
+ o If the sender is not known to you, it is possible that this +
+ is actually generated by a virus and you may safely delete +
+ and ignore this message. +
+ o If this message looks like an official message from some +
+ UW organization and instructs you to open the attachment +
+ to get important information, it is likely to be a fake. +
+ Virus writers are increasingly using this technique (called +
+ "social engineering") to mislead people into doing what they +
+ want. +
+ C&C never sends attachments with information messages about +
+ your account, password, or security issues. Instead, you will +
+ be directed to a Web page on a C&C site. +
+ Further information may be found on the Major Computing and +
+ Network Outages page at +
+ http://www.washington.edu/computing/outages/ +
+ C&C will also post any updates to the Outages page as events +
+ occur. +
+ Please contact help@cac or your local computing support team +
+ if you have further questions. +
</PRE>
