[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Follow up Experimental Broadening question
Hi all,
I have a very short follow up to my recent question about using the EXCHANGE/CORRECTIONS cards to broaden FEFF XANES spectra in a peak fitting process.
We've recently been investigating the DOS and XANES of several oxide spinel samples, and have found that with some samples the best fit to experimental data is given by 1.2eV imaginary broadening, as described by Prof. Rehr in his response to my last email.
Experimental broadening in the data we're comparing against is ~ 0.5eV. This amount of imaginary broadening does not give good agreement - too much fine structure remains.
Searching the literature, I have found that in the published work "Real-space multiple-scattering calculation and interpretation of XANES" (Phys. Rev. B 58, 1998) - Ankudinov, Ravel, Rehr and Conradson, cubic BN XANES had been broadened 1.3 eV, and UF6 DOS broadened 2.0 eV.
So my 1.2eV broadening seems reasonable (?).
Can the experimental and imaginary broadening values be directly compared?
If so, does that indicate my calculation results are incorrect?
If not, is it reasonable to broaden a spectra 1.2eV with FEFF when you know experimental broadening can only be 0.5eV (and also - why?) ?
Thanks for any response, and any indication of what amount of broadening (if any) other users regularly encounter.
Cheers,
David Eustace
