[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: feff820 on Mac
	Hi Paul,
I have been using 8.1 compiled on a Mac with the gcc compiler (and subsequently the absoft) without problem or seg faults (except when I forgot to increase the stack size). I do recall having to change a flag to the absoft compiler (for larger offset sizes) but I don't recall the details (I was a beta tester). Actually the new ibm compiler (in beta) maybe a beta choice however there are lots of minor (looking errors) and I didn't have the time to fix them all. The newest version of feff on leonardo is compiled with the absoft compiler and seems to work fine as well.
The problem is that it is compiled with only 87 atoms in the cluster and lmax=2. I need to increase both (for metals you need at least lmax=3).
By the way, there is no fortran compiler included with the apple distribution -- are you using the fink version of g77?
You are right of course, sorry for the misprint.
 If so, which version?
g77 3.4 (the last version from Fink).
In fact I have succeed to compile with the Absoft compiler (nclusx=250, lmax=3) but iy is unable to find the feff.inp file! I will check this when time available.
Thanks for your help
Best regards
Michel
__________________________________________
 Michel Jaouen
 Universite de Poitiers - UFR Sciences - SP2MI
 LMP UMR 6630-CNRS
 Boulevard Pierre et Marie Curie - Teleport 2
 BP 30179
 86962 Futuroscope - Chasseneuil Cedex
  France
 Tel : (33) 5 49 49 67 37
 Fax : (33) 5 49 49 66 92
 e-mail : Michel.Jaouen@univ-poitiers.fr
