[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: Fe3O4
Hey folks,
David just mentioned a really good way of using Atoms and so I just
wanted to jot off a quick note reiterating that point.
Having Atoms write out the P1 files is an excellent route to dealing
with these kinds of problems.  The P1 output from atoms is itself an
atoms.inp file.  You can run atoms with the P1 file and get the same
feff.inp files (although the atoms might be in a slightly different
order).  The P1 file contains the entire content of the unit cell,
that is, all of the point symmetry and Bravais operations have been
applied to each unique position.  In the case of Fe3O4, the atoms.inp
file has 3 unique positions and the P1 file has all 24 iron locations
and 32 oxygen locations in the primitive cell.
Modifying the P1 file is an excellent approach to introducing
systematic modifications of the sort Dr. Sidorenko was asking about or
the sort that David needed in his problem.
B
 Bruce Ravel  ----------------------------------- ravel@phys.washington.edu
 Code 6134, Building 3, Room 222
 Naval Research Laboratory                          phone: (1) 202 767 5947
 Washington DC 20375, USA                             fax: (1) 202 767 1697
 NRL Synchrotron Radiation Consortium (NRL-SRC)
 Beamlines X11a, X11b, X23b, X24c, U4b
 National Synchrotron Light Source
 Brookhaven National Laboratory, Upton, NY 11973
 My homepage:    http://feff.phys.washington.edu/~ravel
 EXAFS software: http://feff.phys.washington.edu/~ravel/software/exafs/
