[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: Position of the Ef in LDOS
Dear feffuses,
I would like to mention that I have found the same problem that Maurizio
has mentioned. In my case was for MO and MO2 oxides. My additional problem
is that my compounds has a band gap but the Fermi level is not falling
there (I have found states just on the fermi level as maurizio has
mentioned).
Thank you for your help.
Sergio.
On May 22 2003, Maurizio Mattesini wrote:
Dear feffusers
after having plotted the L3-edge (XAS) for a M_{2}S system I've been
trying to assign the peaks on the spectra by looking at the local DOS.
Everything looks fine except the position of the Fermi energy. First I've
plotted the partial DOS and then I have scaled the states with the value
of the Fermi energy given at the top of the ldosNN.dat file. However,
despite this the d-states (the states that are contributing most to the
L-edge) still appear below the Ef, as if they were fully occupied. This
is a bit strange since XAS should be very similar to the unoccupied DOS.
I should also mention that the DOS is made of only one single peak (metal
d-states) which has almost the same shape of the calculated XAS spectra.
To me there is no doubt that the XAS refers to these d-states. I have
also checked the xmu.dat file and there I saw that the L-edge start
effectively from an energy around -10 eV, pointing therefore to the
d-states located just below the Ef.
Now, my question is: when plotting the DOS one has to account for the Ef
value given at the top of the ldosNN.dat file but it is evident that this
is not enough to get the "real DOS". Is there any way to place the Ef in
the DOS plot correctly? Should I further scale my DOS with the value of
the threshold energy of the L-edge?
Any hints will be highly appreciated.
Thank you very much.
Maurizio
Dr. M.S.Moreno
University of Cambridge
Department of Materials Science and Metallurgy
Pembroke Street
Cambridge CB2 3QZ
