[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: no xmu.dat file created when using cfaverage card in feff8.2
dear Anna,
I also found this problem, which Alex Ankudinov solved. There is a bug in feff8.2, which can be solved in the source code and recompiling. I'm pasting the details below. With this fix, the CFAVERAGE card works as detailed in the manual. If you do not have a compiler for the computer you are using, it's possible one of the earlier compiled versions of Feff may work.
Note that the use of the CFAVERAGE card with XANES calculations is potentially inaccurate, because FEFF does not recalculate the scattering potentials at each absorber site. Consequently, Alex discourages use of the CFAVERAGE card with XANES. You should consider calculating each XANES individually, and combining the results (including the normalization factors). This rapidly becomes tedious for large clusters, and ideally, FEFF would have an option to recalculate the potentials at each site within the CFAVERAGE loop. The CFAVERAGE card may work for your calculations, but you should check the results.
regards
ben
The source code fixes:
From: Alex Ankudinov <alex@leonardo.phys.washington.edu>
Thank you for reporting the bug in feff8.2.
I found a quick fix: simply comment out or remove the line
     iabs = 1
in subroutine ffmod6.
After this change, the chi file (EXAFS calculations) or xmu file (XANES calculations) will be produced when using the CFAVERAGE card.
	There's a related bug associated with the use of the potential indexes.
  I also found a fix for this: in subroutine rdinp change lines
c     No gaps allowed in unique pots.  Make sure we have enough
c     to overlap all unique pots 0 to nph.
      do 340  iph = 0, nph
  to
      if (iphabs.gt.0 .and. iatph(0).le.0)   iatph(0) = iatph(iphabs)
      do 340  iph = 0, nph
I.e. you need to insert just one line.
I am using feff8.2 (executable downloaded from the web)
to calculate the XAFS spectra of a cluster and would like to
average over all Ni atoms of the cluster. In the calculation i am also
using the XANES and DEBYE cards.
When using the cfaverage card with ipot 0 for one of the Ni and ipot
1 for the rest of the Ni atoms, i get the program running but no output
xmu.dat file is created.
If i use ipot 1 or ipot 0 for all the Ni atoms then i get the complains:
XANES:
no atoms or overlap cards for unic pot 0
can not calculate potentials, etc.
(See attached file: feff.inp)
RDINP-
or
XANES:
more than one absorbing atom (potential 0)
only one absorbing atom allowed
RDINP
Could you please tell me how i should use the cfaverage card in the feff8.2
version?
I attach the input file.
thanks,
Anna Puig
Content-type: application/octet-stream;
	name="feff.inp"
Content-Disposition: attachment; filename="feff.inp"
Attachment converted: Talc:feff.inp 7 (????/----) (00057230)
Dr. B Gilbert
Visiting Postdoctoral Researcher
Department of Earth and Planetary Sciences
University of California - Berkeley
371 McCone Hall
CA 94720-4767
+1 510 643-9120 (tel:office)
+1 510 643-9980 (fax)
