I've been trying to simulate a multi-electron excitation in Li (LiCl) by
changing the subroutine getorb as described in the previous e-mails (see below).
However, during the procedure I found a couple of serious errors.Here they are:
#1st error messagge#
Feff 8.20
XANES:
LiCl
Calculating potentials ...
free atom potential and density for atom type 0
check number of electrons in getorb.f
This problem can be fixed by changing the 0.001 value to 1.001 in the
following lines (it is not very elegant but it works):
call getorb (nz, ihole, xionin, iunf, norb, norbsc, iorb,
1 iholep, nq, kap, xnel, xnval, xmag)
xk=0
do 411 i=1,norb
411 xk=xk+xnel(i)
if ( abs(nz-xionin-xk) .gt. 1.001) then <--------- (default was 0.001)
call par_stop('check number of electrons in getorb.f')
c stop
endif
However, after a new tentative the calculation crashed with a 2nd error message:WARNING: fatal error in subroutine corval. Try
Dear Maurizio, Your changes to getorb.f are consistent with my suggestions on how to treat a double core hole (e.g., a multi-electron excitation). However, doing this for Li metal to get a 1s0 2s1 configuration is a worst case senario, since then you have two holes in the 1s orbital and only a single electron in the valence band! Although the procedure I described will usually work, I won't be surprised if FEFF complains, since it will try to screen the two holes. Please let us know how it works out. Sincerely, John RehrI have a question concerning the simulation of the 1s double core-hole in Li (for example). According to the last John Rehr's e-mail I tried to edit the subroutine getorb and change the following lines data (iocc( 3,i),i=1,29) /2,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, <----- Li 1s2 2s1 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/ data (ival( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/ data (ispn( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/ into data (iocc( 3,i),i=1,29) /1,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, <----- Li 1s1 2s1 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/ data (ival( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/ data (ispn( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, 1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/
-- Maurizio Mattesini, Ph.D. (room 14204) Condensed Matter Theory Group Department of Physics, Uppsala University Box 530 SE-751 21 (Sweden) Tel. +46 18 471 58 58 Mobile +46 73 970 08 66 Fax +46 18 471 35 24 http://www.fysik4.fysik.uu.se/
