[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: Double core-hole
Dear all
I have a question concerning the simulation of the 1s double core-hole in Li (for example). According to the last John Rehr's
e-mail I tried to edit the subroutine getorb and change the following lines
data (iocc( 3,i),i=1,29) /2,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, <----- Li 1s2 2s1
1 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0/
data (ival( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0,
data (ispn( 3,i),i=1,29) /0,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0,
into
data (iocc( 3,i),i=1,29) /1,1,0,0,0, 0,0,0,0,0, 0,0,0,0,0, <----- Li 1s1 2s1
and then I have recompiled the program. Now, as far as I understand the calculation of the XANES for the 1st case will simulate the Li K-edge with a single 1s core hole, providing the use of the card HOLE=1. That is, the z+1 approximation will emulate the 1s1 2s1 configuration. By analogy, the 2nd case should therefore simulate the double 1s core-hole (e.g., 1s0 2s1). Is this procedure correct? I'd really appreciate any comments on this. Furthermore, which is the right way to follow the electronic charge redistribution on the absorber atom and around its 1st coordination shell?
Best regards,
Maurizio
John J. Rehr wrote:
Dear Maurizio,
 This is an interesting question.  For deep double-core hole excitations
one can do this with a little recoding. Namely you have to modify the entries
in subroutine getorb (do a search on ine getorb) and by hand alter the
entries for the particular level you want to be the 2nd hole.  Then
recompile and run. The absorption should then be that for a 2 core hole
state. The excitation energies won't be right, but you can align the
results to experiment. It's not something for a novice user, unfortunately.
 Please let me know if you have difficulty doing this and we can
assist e.g., for some sample double hole state.
 Similar modification of getorb can be used to deal with fractional
core hole states. This has also been done many times.
With best wishes,
 John Rehr
