[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re: LDOS
Dear feff users,
I´m running the FEFF8.2 version with the option LDOS. When
the program is finished, I have 4 files of LDOS, ldos00, ldos01,
ldos02, ldos03. In each file, I have four columns with s, p, d and f
in the top of the columns.
Could you help me to understand the meaning of each file and
of each column? I´m running the program to do the calculation of the
XANES spectra of PbTiO3 compound.
It is clear from the feff manual :
ldos00 is for potential index 0 (central atom)
ldos01 is for potential index 1
and so on (ldosnn is for potential nn).
Therefore it's normal to obtain 4 in your case : one for the central
(eg Pb with a core hole if Pb is your absober), one for Pb (neutral),
one for Ti and the last for O. To know what is what, read your
potential index in the feff.inp file). The meanning of the columns is
obvious : 1st column is the energy (referenced to its muffin-tin
value : to have the correct energy scale, eg the Fermi level, you
must look at the mu-new value obtained at the end of the scf module),
the second is the broadening used for ldos convolution (default 0.2,
don't use 0), then the ldos (s,p d, f in your case since you have used
lmax = 3 in potential card).
Regards
M. jaouen
__________________________________________
Michel Jaouen
Universite de Poitiers - UFR Sciences - SP2MI
LMP UMR 6630-CNRS
Boulevard Pierre et Marie Curie - Teleport 2
BP 30179
86962 Futuroscope - Chasseneuil Cedex
France
Tel : (33) 5 49 49 67 37
Fax : (33) 5 49 49 66 92
e-mail : Michel.Jaouen@univ-poitiers.fr
- LDOS
