[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Long LDOS calculation times with simple structures
Hello all,
At present I am trying to run LDOS calculations on simple rock salt structures to establish the parameters I want to use on more complicated materials. I'm having a bit of a problem with the length of time these calculations take. We run feff 8.1 on an alpha dec computer, with a dual processors. I'm not looking to upgrade the system specs, I'm referring to the time these calculations take relative to others we run (they take two or three days longer).
After running an initial calculation with all control modules on, which I'm not really concerned about, I vary my LDOS parameters then run with only the second module.
To get decent resolution on my plots, I have reduced the energy range over which I'm calculating the LDOS, but still require a very large number of atoms to obtain fine structure (about 300-450). This makes my calculations take a long time (typically between 3 and 5 days), although they have started yielding . Typical detailed calculations on our system usually take 1-2 days.
I reckon because I'm using a simple structure, good resolution requires long scattering lengths. If I'm wrong, please let me know. I use the FMS card to define scattering length, I omit the SCF card.
I was wondering if there was any way of making these calculations go faster? All I'm looking to obtain is the LDOS, i.e. the rholnn.dat (ldosnn.dat on feff 8.2) files. Is it possible to 'omit' other functions performed by the second control module? (I only run the LDOS and FMS cards in my input file).
I hope these are reasonable questions, many thanks for any help you can give me,
David Eustace
