[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
Re-starting a calculation
Paula Harkins asked about restarting a FEFF8 calculation:
>I am using Feff8 (ver 8.1) and wondered if there was any way to restart a
>calculation from the point that it was stopped at rather than having to
>wait for the whole calculation to run again. (I share my computer with
>several other users!) Any ideas?
At present this can only be done module by module. For example if a
calculation stops during the 3rd module [FMS], it is not necessary to
rerun the first two modules and one can restart the calculation with
CONTROL 0 0 1 1 1 1
You can check that a module has finished by looking at the last line
in logn.dat. For example, when the potentials have been calculated the
last line should say:
Done with module 1: potentials.
What else can be done?
If you do want to stop a job temporarily, you can use the ctrl-z command
in unix to stop a job and then restart later with the command fg.
Several things can be done to optimize the speed to avoid the need for
stopping/restarting:
i) For XANES calculations, the time goes up as [N(lmax+1)**2]**3,
so you should keep the cluster size as small as you can get away
with without sacrificing accuracy [typically 30-40 atoms] and
with default lmax [set lmax = -1 in POTENTIALS].
ii) For the FMS part, if you have FEFF8.2 the calculations go faster with the
Lanczos algorithm.
We'll look into the possibility of restarting a FEFF8 calculation mid
module. Certainly some band structure codes allow one to restart during
the SCF loop.
Cheers,
John Rehr
