[Date Prev][Date Next][Thread Prev][Thread Next][Date Index][Thread Index]
question
Stéphanie Belin asked:
SB> Hello, I would like to ask you a question about ATOMS and FEFF.
SB> I want to calculate an exafs spectrum of a non-stoichiometric
SB> coumpound, and my problem is that ATOMS doesn't take into account
SB> occupation ratio (fractional occupancies) on the cristallographic
SB> positions of atoms. So, I would like to know the best way to
SB> proceed ? Moreover, these positions are occupied by two
SB> different atoms ... I tried to modify FEFF.INP file, but It
SB> can't reproduce the real structure. Thank you for your
SB> attention. Sincerely yours.
The explanation of why Atoms does not and *cannot* translate
occupation fractions into the feff.inp file can be found in the Atoms
document. Here is the URL that jumps straight to the explanation:
http://leonardo.phys.washington.edu/~ravel/software/atoms/doc/Atoms/node4.html#SECTION00442000000000000000
In my course on EXAFS analysis, I discuss the problem of mixed
shells. The course home page is
http://leonardo.phys.washington.edu/~ravel/course/
I describe some techniques for solving this problem using feff and
feffit in Chapter 10 of this PDF file:
The short answer is that it is somewhere between hard and impossible
to properly model exafs on a mixed shell with a single feff run. My
solution described above requires running feff two or more times and
combining the output of those feff runs using your fitting program.
Check out that stuff and if that doesn't help, post here again and
hopefully I or someone else will offer some useful wisdom for you.
Good luck
Bruce
Bruce Ravel ----------------------------------- ravel@phys.washington.edu
U.S. Naval Research Laboratory, Code 6134 phone: (1) 202 767 5947
Washington DC 20375, USA fax: (1) 202 767 1697
NRL Synchrotron Radiation Consortium (NRL-SRC)
Beamlines X11a, X11b, X23b, X24c, U4b
National Synchrotron Light Source
Brookhaven National Laboratory, Upton, NY 11973
My homepage: http://feff.phys.washington.edu/~ravel
EXAFS software: http://feff.phys.washington.edu/~ravel/software/exafs/
