Next: Two methods of isolating
Up: DAFS ANALYSIS METHODS
Previous: DAFS ANALYSIS METHODS
One of the important corrections is for the absorption of the incident
and diffracted x-ray beams as they travel through the sample.
Three possible absorption correction methods are:
- For small absorption corrections, intensity formula, and the
effective
produced by the direct spline analysis method can be
appropriately phase shifted. This method is illustrated by the direct
spline analysis of the Cu data presented in Section 5.
- The absorption correction can be reconstructed from the simultaneous
fluorescence measurements. This method is illustrated by the iterative
Kramers-Kronig analysis of the Cu and
YBa2Cu3O6.6 data
presented in Sections 5, 7 and 8.
- The absorption correction could also be constructed self-consistently
using the f'' functions obtained during the iterative Kramers-Kronig
analysis of the DAFS signal.
It is important to remember that the absorption
signal is
different than the DAFS
and
signals because XAFS weights
the sites based on the number of atoms within the unit cell, whereas DAFS
weights the sites crystallographically. Thus measurements of the single
function are not sufficient to determine the multiple
and
functions for systems which contain multiple inequivalent
sites.
