There are some issues with fitting FeNi DAC parameters using fdmnes.
20 Dec
2025
20 Dec
'25
5:20 a.m.
Hello! I am a graduate student. When using Fdmnes to fit FeNi DAC, I found that the fitted peaks do not match the experimental peaks very well. The main issue is that the two transition peaks in the experiment merge into a single peak in the fitted curve. First of all, thank you very much for your help. If you could help me adjust the parameters, I would be happy to send you the experimental data for you to take a look. Best of luck!
212
Age (days ago)
212
Last active (days ago)
0 comments
1 participants
participants (1)
1000566384@smail.shnu.edu.cn
